[postgis-users] [Raster] MNT 250 IGNF data import problem
Tumasgiu Rossini
rossini.t at gmail.com
Tue Oct 22 13:19:33 PDT 2013
Some tiles generated from the MNT file might be filled with nodata value
(-9999) so I guess that explains some "anormal" statistics values...
You should execute the statistics statement against all tile to check if
all statistics are the same...
I suggest you to test some commands from your home-compiled GDAL (gdalinfo
-hist for example) too.
Also, data from MNT files seems to be integer values, I don't think that
the correct pixel depth is 32BF.
For the QGIS issue, I think that mnt data is improper for display and
should be processed into "displayable" raster data, such as GrayScale or
TrueColors Bitmap. To do so, you might consider use st_colormap().
2013/10/22 Yves Jacolin <yves.jacolin at camptocamp.com>
> Hello,
> Yes it uses 32BUI (as far I can remember). I will check tomorrow and
> made more test.
> Thanks,
> Y.
> 2013/10/22 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>:
> >> Because I did a quick test and copied past previous SQL requests and I
> did
> >> not
> >> clean it before! Of course you can remove the next 2 bands which don't
> >> exist
> >> but the first one should have correct statistic.
> >> Thanks Pierre to let me know the logical ;)
> > Sorry I thought you were complaining about the error message not about
> the stats....
> > MNT250_L93_FRANCE.ASC is a text file right? I would suspect a bad
> interpretation of the decimal separator.
> > Check also what pixeltype was used by the importer with
> ST_BandPixelType() or ST_BandMetadata(). I suspect it used 32BUI (because
> it does not recognize the separator) when it should use 32BF.
> > Pierre
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131022/64b36ad2/attachment.html>
