[postgis-users] Question about SDE on top of Postgres . . .
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Mon Oct 28 07:51:49 PDT 2013
Paul,
Ours is all linux based (SUSE), so the windows part wasn't bothering me. There did seem to be a lot of steps to follow in order to make it work though. Our SDE folks are still settling on what to have in place as a DB. Oracle is the front runner, but I was hoping to be able to demonstrate PostGIS as an option. Just looking at options right now.
Bobb
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Sunday, October 27, 2013 4:20 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Question about SDE on top of Postgres
> Wow, that page really goes out of its way to make sure you don't
> want to use PostGIS! All those notes and caveats in the PostGIS
> boxes!
> "Beginning with ArcGIS 10.1, all databases used with ArcGIS must
> be 64-bit" WHAT?!?!? Client apps, by and large, don't give a damn
> about what platform the database is running on. PgSQL in
> particular speaks client/server in a protocol that doesn't care.
> The only thing about PgSQL that would *have* to match the
> architecture of ArcGIS is the client library (libpq.dll) and ESRI
> will have built and bundled that into ArcGIS themselves using the
> proper architecture. So, ignore all the items that say you can't
> do Windows because there's no 64 bit build available: it'll work
> fine.
> P.
> On Sat, Oct 26, 2013 at 6:18 PM, BladeOfLight16
> <bladeoflight16 at gmail.com> wrote:
> > On Fri, Oct 25, 2013 at 11:27 AM, Basques, Bob (CI-StPaul)
> > <bob.basques at ci.stpaul.mn.us> wrote:
> >> Sorry, I guess I should have looked just a little more before
> posting
> >> the question . . . .
> http://support.esri.com/en/knowledgebase/techarticles/detail/40553
> > You may want to consider trying 9.1 with PostGIS 2.0 despite
> what this
> > documentation states. It says that the problem with 2.0 and
> older
> > clients is an incompatibility between PostGIS 2.0 and 1.5
> functions,
> > but PostGIS 2.0 provides a legacy.sql. legacy.sql will create
> the
> > PostGIS 1.5 functions removed in 2.0. See
> > http://postgis.net/docs/postgis_installation.html for
> instructions on
> > using legacy.sql. I realize this is not necessarily "officially"
> > supported by ESRI, but I suspect it will work anyway. Probably
> worth a try.
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
