[postgis-users] tile size
Stephen Crawford
src176 at psu.edu
Fri Sep 13 09:34:22 PDT 2013
OK, thanks. I will give that a try.
On 9/13/2013 12:31 PM, Adam Eskreis wrote:
> The most common tile size that I've seen in production is 256x256
> On Fri, Sep 13, 2013 at 10:33 AM, Bborie Park <dustymugs at gmail.com
> <mailto:dustymugs at gmail.com>> wrote:
> Steve,
> There really isn't. What I do recommend is that if your raster
> data is not going to change over time (and you don't need to
> replicate the database), load them as out-db rasters. That way,
> you can easily change tile size within the database with ST_Tile.
> -bborie
> On Fri, Sep 13, 2013 at 6:06 AM, Stephen Crawford <src176 at psu.edu
> <mailto:src176 at psu.edu>> wrote:
> Hi All,
> Is there a rule of thumb for determining the best tile size
> when tiling a raster?
> Thanks,
> Steve
> Stephen Crawford
> Center for Environmental Informatics
> The Pennsylvania State University
> <tel:814.865.9905>
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Stephen Crawford
src176 at psu.edu
814.865.9905
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130913/896d1c6d/attachment.html>
