[postgis-users] tile size
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Sep 19 08:36:19 PDT 2013
You can also have a look at this article from Duncan Golicher if you are doing raster/vector analysis:
http://duncanjg.wordpress.com/2012/10/30/tile-size-for-raster-vector-overlays-in-postgis/
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Stephen Crawford
> Sent: Friday, September 13, 2013 12:34 PM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] tile size
> OK, thanks. I will give that a try.
> On 9/13/2013 12:31 PM, Adam Eskreis wrote:
> The most common tile size that I've seen in production is 256x256
> On Fri, Sep 13, 2013 at 10:33 AM, Bborie Park
> <dustymugs at gmail.com> wrote:
> Steve,
> There really isn't. What I do recommend is that if your raster
> data is not going to change over time (and you don't need to replicate the
> database), load them as out-db rasters. That way, you can easily change tile
> size within the database with ST_Tile.
> -bborie
> On Fri, Sep 13, 2013 at 6:06 AM, Stephen Crawford
> <src176 at psu.edu> wrote:
> Hi All,
> Is there a rule of thumb for determining the best tile
> size when tiling a raster?
> Thanks,
> Steve
> Stephen Crawford
> Center for Environmental Informatics
> The Pennsylvania State University
> <tel:814.865.9905>
> postgis-users mailing list
> http://lists.osgeo.org/cgi-
> bin/mailman/listinfo/postgis-users
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-
> users
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Stephen Crawford
> src176 at psu.edu
> 814.865.9905
