[postgis-users] looking for a public well known maven repository for postgis-jdbc 2.1 and later on versions
Baris Ergun
barisergun75 at gmail.com
Fri Apr 4 12:43:18 PDT 2014
Basically let me summarize you the mechanism. By putting postgis jdbc
driver on ur classpath and using postgis objects provided by it "postgis
datatypes" are registered to be written and parsed with the BinaryWriter
and BinaryParser in Postgis jdbc driver. Both 'jdbc:postgresql_postGIS' and
'jdbc:postgresql' are valid usages. What happens is when you specify
postgis jdbc jar DriverWrapper translates your jdbc url to 'jdbc:postgresql'
and provides the connection to db. And when you specify 'jdbc:postgresql'
postgresql jdbc driver is used for establishing connection.
Returning to ur problem I need more detailed description, but I suspect
that you are using an older version of Java which is not compatible with
your jdbc drivers. Without giving me more detailed information of ur
problem; you have pressed "Im feeling Lucky" button to get that answer ;)
On 4 April 2014 16:31, Paul Mendelson <mendelson.paul at gmail.com> wrote:
> My problem is when I have the postgis jdbc driver and the postgress 9.3
> jdbc driver in my classpath I get method not found errors. This may be a
> naive question will the postgis driver work with both
> jdbc:postgresql_postGIS://localhost:5432/
> and
> jdbc:postgresql://localhost:5432
> On Thursday, April 3, 2014 2:40:52 PM UTC-4, Baris Ergun wrote:
>> Hi Paul;
>> You should have another issue we are currently using 1.3.3 with
>> postgresql 9.3. What kind of problem you are having. What is the exact
>> problem. PS: There is an ongoing effort to make postgis-jdbc drivers
>> publicly available on central OSSRH rep.
>> On 3 April 2014 19:57, Paul Mendelson <mendels... at gmail.com> wrote:
>>> I am having the same problem the 1.3.3 driver does not work with the
>>> postgres 9.3 driver.
>>> On Monday, December 16, 2013 7:57:11 AM UTC-5, Baris Ergun wrote:
>>>> Why cant I find an official postgis-jdbc for 2.1 version and on; on a
>>>> well known maven repository? The latest version on central maven is
>>>> 1.3.3.
>>>> I will discuss to put 2.1 on our own repository but I just wanted to
>>>> know
>>>> the reasoning behind this obscurity? Or am i wrong?
>>>> Hope to hear from you.
>>>> Baris
>> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140404/2f99e980/attachment.html>
