[postgis-users] Export from postGIS to ESRI Personal GeoDatabase
Robert Burgholzer rburghol at vt.edu
Tue Dec 2 13:56:03 PST 2014
Thanks George - I will check this out.  I think that your method of
detailing the various tables to include WILL be useful for me.  What I am
less sure about is whether or not this will export "links" from tables...
but then again, I do not even know if personal geoDB will support that...
In other words, my goal is to give my users something with a structure that
holds features in one table, then associates those features with various
properties tables.
As an aside, this is a pretty typical use case, I have inherited
stewardship of a ShapeFile with 58,000 rows in it, and 135 columns.  I
pulled it into a nicely  atomized and structured PostgreSQL db, but my
users really want me to give them a daily dump of the old 58,000x135 shape
file -- I want to lure them away from such abominations...
On Tue, Dec 2, 2014 at 2:23 PM, George Silva <georger.silva at gmail.com>
wrote:
> Hello Robert,
> If your slave copy is read-only, you can setup a export job using ogr2ogr
> to generate the File Geodatabase daily.
> Personal Geodatabase are not supported, but File Geodatabase are. You'll
> need to compile GDAL with FGDB support, that must be installed separately.
> Some Geodatabase features are not supported via export directly, such as
> the creation of Feature Datasets.
> Check this gist:
> https://gist.github.com/george-silva/787861408555572ad100
> The main export.sh script takes up a few parameters, so you can pass them
> along. This uses a table inside postgresql to know in advance about the
> layers I have and those that need to be exported.
> This is bit more sophisticated, but you can hardcode your script and it
> will work the same.
> Let me know how that works out for you.
> On Tue, Dec 2, 2014 at 4:37 PM, Robert Burgholzer <rburghol at vt.edu> wrote:
>> Wondering if anyone has any experience running from PG to ESRI mdb.
>> Basically, we want to use PostGIS as our master, and then replicate in
>> GeoDB format for field personel to reference when they are unable to
>> connect to the Web due to remote location (which happens very frequently in
>> our line of work).
>> Any thoughts, experiences would be welcome.
>> Robert W. Burgholzer
>>  'Making the simple complicated is commonplace; making the complicated
>> simple, awesomely simple, that's creativity.'  - Charles Mingus
>> Athletics: http://athleticalgorithm.wordpress.com/
>> Science: http://robertwb.wordpress.com/
>> Wine: http://reesvineyard.wordpress.com/
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> George R. C. Silva
> SIGMA Consultoria
> http://www.consultoriasigma.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141202/8fdce258/attachment.html>
