[postgis-users] Export from postGIS to ESRI Personal GeoDatabase
George Silva
georger.silva at gmail.com
Tue Dec 2 18:57:11 PST 2014
By links you mean...Foreign Keys? I don't think relationships are
supported. If you have access to some ESRI libraries, you can create the
geodatabase and throw together an ArcPy script to create the relationships
back together.
If by links you mean textual links to files or urls, yes they will be
supported. You will need to configure the hotlink feature inside arcgis.
You broke up the structure inside the PostGIS database. Create a view to
put it all back together, and export the view.
I'm not sure why your users insist with Personal Geodatabase. There's only
one use case for it: use it along with access to edit some records faster.
If all they use is ArcGIS, it won't matter to them. They'll be able to do
all the same things.
Check out that gist again, I've added the table definition. My use case is
similar. I have a whole different structure here, with proper foreign keys,
etc, and views that concatenate all the useful info for end-users and I
export those.
For reference:
/* Infraestrutura geral. */
CREATE SCHEMA temporario;
CREATE TABLE camada (
id SERIAL PRIMARY KEY, esquema varchar(256) NOT NULL DEFAULT
'public', nome_tabela
varchar(256) NOT NULL, nome varchar(256) NOT NULL, descricao
varchar(512), exportar
BOOLEAN DEFAULT TRUE, nome_view varchar(512) NULL );
esquema = schema;
nome_tabela = table_name;
nome = name (textual description);
descricao = description;
exportar = export, true or false (the function uses this for reference);
nome_view = view name, name of the view that holds the data for layer xyz
In a certain case, I had:
CREATE TABLE landuse (
landuse INTEGER REFERENCES landuse_code(id)
geometry Polygon(4326));
CREATE TABLE landuse_code (
landuse VARCHAR(256));
CREATE VIEW vw_landuse AS
SELECT
l.id,
code.landuse,
l.geometry
FROM
landuse l
LEFT JOIN landuse_code code ON (l.landuse = code.id);
Them I inserted that into my layer table, specifying the view and the table
info (the view_name column expects this to be fully qualified, if you are
placing your views in another schema, it should be schema.view) and running
that script to create the File Geodatabase.
Cheers
On Tue, Dec 2, 2014 at 11:49 PM, Roxanne Reid-Bennett <rox at tara-lu.com>
wrote:
> On 12/2/2014 1:37 PM, Robert Burgholzer wrote:
>> Wondering if anyone has any experience running from PG to ESRI mdb.
>> Basically, we want to use PostGIS as our master, and then replicate in
>> GeoDB format for field personel to reference when they are unable to
>> connect to the Web due to remote location (which happens very frequently in
>> our line of work).
>> Any thoughts, experiences would be welcome.
> I can't speak to ESRI mdb.
> But.. Our mobile developer used an old (now unsupported) package [I don't
> know the name] with some tweaks to add LibGEOS support to SQLLite. If you
> want to know more about that port - I can certainly make inquiries. Our
> Web SaaS system runs on PG and the mobile app is connecting to that to pull
> data down to be available offline, which sounds a lot like your
> architectural needs.
> Roxanne
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
George R. C. Silva
SIGMA Consultoria
http://www.consultoriasigma.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141203/59545902/attachment.html>
