[postgis-users] PostGIS migrations
James Sewell james.sewell at lisasoft.com
Sun Jun 1 20:12:43 PDT 2014
Greetings All,
I am currently investigating a migration from 8.1.23 / 1.3.6 to 9.3.4 / 2.1.3.
I have a few questions regarding best practice for this. I'm using a
dump / restore approach.
1. Is there any problem with installing PostGIS into a postgis213
schema instead of into public? It seems a bit cleaner to me, and would
make future upgrades or dumps a lot smoother. I can then use ALTER
DATABASE to ensure that it is always in the search path.
2. Is the postgis_restore.pl script still reccomended? I've given it a
trial and it seems to work well (with a few small tweeks to support
the schema change above).
3. Is there any automated way to go from geometry contraints to using
the correct geometry type (ie: geometry(Point, 4326) ) Is this
something which I should not be doing for some reason?
Anything else I should be looking out for with a migration across
these versions?
Thanks for your help,
James Sewell,
PostgreSQL Team Lead / Solutions Architect
______________________________________
 Level 2, 50 Queen St, Melbourne VIC 3000
*P* (03) 8370 8000 * **W* www.lisasoft.com  *F*(03) 8370 8000
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
email is free of viruses or other defects. If you have received this
communication in error, you may not copy or distribute any part of it or
otherwise disclose its contents to anyone. Please advise the sender of your
incorrect receipt of this correspondence.
