[postgis-users] Versioning system to use with QGIS + Postgis
Alexandre Neto senhor.neto at gmail.com
Fri Jun 6 02:00:56 PDT 2014
Il 06/06/2014 08:18, Hugues François ha scritto:
> You could also have a look at Vincent Mora’s recent work at Oslandia :
> https://github.com/Oslandia/qgis-versioning
Thanks Hugues, this one I did not know.
On Fri, Jun 6, 2014 at 9:08 AM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Il 06/06/2014 00:28, Alexandre Neto ha scritto:
> > I already knew about pgversion, but I haven't been able to see its code
> http://plugins.qgis.org/plugins/pgversion/ >
> https://www.kappasys.ch/svn/pgversion/trunk/
Paolo, thank you for the links. I have tried to find this before, but the
plugin no longer appears in QGIS, and the oficial page (
http://www.kappasys.ch/cms/index.php?id=23&L=5) seems empty. The plugin is
not updated for QGIS 2.X.
> Unifying the efforts, rather than duplicating, seems a sensible way.
Of course it's the best way to go. Lets see if my skills are enough to be
able to make a valid contribute.
Best regards,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140606/e272e4ef/attachment.html>
