[postgis-users] Versioning system to use with QGIS + Postgis
Hugues François hugues.francois at irstea.fr
Fri Jun 6 02:10:47 PDT 2014
It has been presented at recent conference foss4g-fr, you may find more information here : https://osgeo-fr.github.io/presentations_foss4gfr/2014/J1_B_14_30_QGIS_DISTRI_EAU/foss4gfr_2014_qgis_distribution_metier_eau_picavet.pdf
Unfortunately, it’s in French (which seems normal since it was for the French foss4g…)
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Alexandre Neto
Envoyé : vendredi 6 juin 2014 11:01
À : Paolo Cavallini; PostGIS Users Discussion
Objet : Re: [postgis-users] Versioning system to use with QGIS + Postgis
Il 06/06/2014 08:18, Hugues François ha scritto:
> You could also have a look at Vincent Mora’s recent work at Oslandia :
> https://github.com/Oslandia/qgis-versioning
Thanks Hugues, this one I did not know.
On Fri, Jun 6, 2014 at 9:08 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
Il 06/06/2014 00:28, Alexandre Neto ha scritto:
> I already knew about pgversion, but I haven't been able to see its code
http://plugins.qgis.org/plugins/pgversion/ >
https://www.kappasys.ch/svn/pgversion/trunk/
Paolo, thank you for the links. I have tried to find this before, but the plugin no longer appears in QGIS, and the oficial page (http://www.kappasys.ch/cms/index.php?id=23&L=5) seems empty. The plugin is not updated for QGIS 2.X.
	Unifying the efforts, rather than duplicating, seems a sensible way.
Of course it's the best way to go. Lets see if my skills are enough to be able to make a valid contribute.
Best regards,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140606/417c3918/attachment.html>
