[postgis-users] Versioning system to use with QGIS + Postgis
Hugues François hugues.francois at irstea.fr
Thu Jun 5 23:18:16 PDT 2014
You could also have a look at Vincent Mora's recent work at Oslandia : https://github.com/Oslandia/qgis-versioning
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de José Carlos Martínez Llario
Envoyé : jeudi 5 juin 2014 18:51
À : postgis-users at lists.osgeo.org
Objet : Re: [postgis-users] Versioning system to use with QGIS + Postgis
pgversion is a nice approach and there is a QGIS plugin too.
I tried it a couple of years ago and I liked it.
It is programmed using plpgsql so you can improve it or study the source code easily
http://www.kappasys.ch <http://www.kappasys.ch>
On 05/06/2014 18:43, Alexandre Neto wrote:
	Hello all,
	I have been working on a versioning system to be used with QGIS.
	This is probably a very naive approach since I'm no expert in Postgres, but I would like to ear some comments and suggestions to improve it.
	The work is based on the versioning system of QGIS, but I wanted to improve two things:
	1 - Keep always the same primary key of features;
	2 - Only save\backup changed columns instead of the full similar rows;
	Thanks for your help
	Alexandre Neto
	postgis-users mailing list
	postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
	http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
http://cartosig.upv.es
Producción Cartográfica y SIG.
Dpto. Ingeniería Cartográfica.
Univ. Politécnica de Valencia.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140606/0de04dd7/attachment.html>
