[postgis-users] Versioning system to use with QGIS + Postgis
tommaso tommasodb at googlemail.com
Thu Jun 12 13:57:45 PDT 2014
Hello, a completely different approach:
http://geogit.org/
Not sure it is suitable for your case but in my opinion very promising.
Tommaso
On 06/06/2014 08:18 AM, Hugues François wrote:
> Hi,
> You could also have a look at Vincent Mora's recent work at Oslandia :
> https://github.com/Oslandia/qgis-versioning
> Hugues.
> *De :*postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] *De la part de* José
> Carlos Martínez Llario
> *Envoyé :* jeudi 5 juin 2014 18:51
> *À :* postgis-users at lists.osgeo.org
> *Objet :* Re: [postgis-users] Versioning system to use with QGIS + Postgis
> Hi,
> pgversion is a nice approach and there is a QGIS plugin too.
> I tried it a couple of years ago and I liked it.
> It is programmed using plpgsql so you can improve it or study the
> source code easily
> http://www.kappasys.ch
> On 05/06/2014 18:43, Alexandre Neto wrote:
>     Hello all,
>     I have been working on a versioning system to be used with QGIS.
>     This is probably a very naive approach since I'm no expert in
>     Postgres, but I would like to ear some comments and suggestions to
>     improve it.
>     The work is based on the versioning system of QGIS, but I wanted
>     to improve two things:
>     1 - Keep always the same primary key of features;
>     2 - Only save\backup changed columns instead of the full similar rows;
>     Thanks for your help
>     Alexandre Neto
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> José Carlos Martínez Llario
> http://cartosig.upv.es
> Producción Cartográfica y SIG.
> Dpto. Ingeniería Cartográfica.
> Univ. Politécnica de Valencia.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140612/531b3cbc/attachment.html>
