[postgis-users] raster support
Stefan Keller
sfkeller at gmail.com
Sat Jun 7 23:52:57 PDT 2014
Salut Pierre
Can you help on how to display PostGIS Raster in QGIS 2.x exactly?
I've found this
http://postgis.17.x6.nabble.com/Problem-with-postgis-raster-td5006344.html
but it's not specific on how to achieve this.
In addition, do you think QGIS needs a Python plugin (before it manages to
be adapted by QGIS core)?
Yours, Stefan
2014-06-05 20:40 GMT+02:00 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>:
> These variables are system variables, not PostgreSQL variables. to know
> how to set them in your system search for "set environment variable os x".
> Pierre
> > -----Original Message-----
> > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> > bounces at lists.osgeo.org] On Behalf Of John Payne
> > Sent: Sunday, June 01, 2014 10:25 AM
> > To: postgis-users at lists.osgeo.org
> > Subject: [postgis-users] raster support
> > I want to store raster data in PostGIS. I am using Postgresql 9.2.4 with
> > PostGIS 9.1.0 on a Mac Powerbook running OS X 10.8.5. I want to use the
> > command "raster2pgsql" but I get an error message saying that the type
> > "raster" was not recognized.
> > I think the problem may be (from Chapter 2.1 of the PostGIS manual):
> > "As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are
> disabled by
> > default. In order to re-enable these, you need to set the following
> > environment variables:POSTGIS_GDAL_ENABLED_DRIVERS and
> > POSTGIS_ENABLE_OUTDB_RASTERS in the server environment"
> > I tried adding the following to the end of my postgresql.conf file:
> > POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
> > POSTGIS_ENABLE_OUTDB_RASTERS=1
> > However, it generated an error message saying that the variables weren't
> > recognized. Can anyone tell me how to set them?
> > Thanks,
> > John
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140608/4588f330/attachment.html>
