[postgis-users] Windows Installer failing - destination folder issue
Matthew Baker mattbaker at gmail.com
Fri Jun 20 12:26:15 PDT 2014
Hi all,
Just tried the windows installer, and its failing due to the
installation destination for PostGIS.
I can choose the destination folder ok:
[screen capture]
(C:\Program Files\PostgreSQL\9.3\)
However, when the installation gets kicked off, an error stops the
installation, stating "PostGIS has to be
installed to the PostgreSQL folder".
[screen capture]
What is the "output folder" in the above dialogue, that seems to be
pointing deep into the C:\users\userName\etc. etc. location - is that
the temp directory for the installation files, or the path that PostGIS
is trying to install?
So... why isn't the destination folder being used for the installation
as instructed?
Download files pulled from here:
http://download.osgeo.org/postgis/windows/pg93/
32-bit file: postgis-bundle-pg93x32-setup-2.1.3-1.exe
Thank you!
-Matthew Baker
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140620/632f0553/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140620/632f0553/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140620/632f0553/attachment-0001.png>
