[postgis-users] box3d overlap
Martijn Meijers b.m.meijers at tudelft.nl
Fri Jun 20 05:41:05 PDT 2014
Ok, to answer my own question: It does indeed project to 2D (when
arguments are both of box3d type, and not when it is a geometry).
gisbase=> select 'LINESTRINGZ(0 0 0, 10 10 10)' &&& 'LINESTRINGZ(0 0 90,
10 10 100)';
  ?column?
  f
(1 row)
gisbase=> select 'LINESTRINGZ(0 0 0, 10 10 10)'::geometry::box3d &&&
'LINESTRINGZ(0 0 90, 10 10 100)';
  ?column?
  f
(1 row)
'LINESTRINGZ(0 0 90, 10 10 100)'::geometry::box3d;
  ?column?
  t
(1 row)
Maybe the documentation should be more specific about this behaviour.
On 06/20/2014 01:17 PM, Nicklas Avén wrote:
> Hallo Martijn
> Here is more than one problem I think.
> In the case of ST_Overlaps and ST_Intersects they only work on 2d.
> ST_3DIntersects work on 3d or actually 2.5d because the function
> doesn't understand volumes which a box is.
> I am actually not sure how the box is casted before feeded as a
> geoemtry to the functions. Someone might answer that.
> About the behavior of &&& I am also confused, and maybe suspects
> something not working as expected.
> I thought &&&-operator would work on the box type.
> /Nicklas
> 2014-06-20 Martijn Meijers wrote:
> Hi,
> >I am rather puzzled by the following:
> >select 'BOX3D(0 0 0, 10 10 10)'::box3d &&& 'BOX3D(0 0 90, 10 10
> >100)'::box3d;
> > ?column?
> > t
> >select st_overlaps('BOX3D(0 0 0, 10 10 10)'::box3d, 'BOX3D(0 0 90, 10 10
> >100)'::box3d);
> > st_overlaps
> > f
> >select st_intersects('BOX3D(0 0 0, 10 10 10)'::box3d, 'BOX3D(0 0 90, 10
> >10 100)'::box3d);
> > st_intersects
> > t
> >(1 row)
> >Should these queries not all return false (as the boxes do not share any
> >space)?
> >Or is it because these functions do not (yet) support 3D (and operate on
> >the projected 2D primitives)?
> >If so, I find the documentation for the &&& operator rather confusing...
> >Martijn
> >Martijn Meijers
> >mailto:b.m.meijers at tudelft.nl
> >http://www.gdmc.nl/martijn
> >GIS-technology
> >Faculty of Architecture and the Built Environment
> >Delft University of Technology
> >P.O. Box 5030 | Jaffalaan 9 (Building 30)
> >2600 GA Delft | 2628 BX Delft
> >The Netherlands
> >tel (+31) 15 2785642
> >fax (+31) 15 2782745
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at lists.osgeo.org
> >http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Martijn Meijers
GIS-technology
The Netherlands
