[postgis-users] Assert on ST_Buffer crashes database
rox
rox at tara-lu.com
Mon Mar 10 08:21:10 PDT 2014
We have been experience an intermittent problem with an ASSERT
generated from the RightmostEdgeFinder module in the PostGIS
layer that crashes our production Postgres database. Generally we
modify the geometries or add a slight massage
(like Buffer(geom,0)) to the query that sources the ASSERT to avoid the
crash for the specific scenario(s)
we find. We run into this problem about every 2 months or so.
Isolating which geometries are causing
the problem and fixing them or modifying the query to not fail has been
very manpower intensive. [and .. did I mention
it crashes the production database?]
Does anybody have better ideas for us to prevent or catch/capture and
handle these errors?
Implementation Details:
We are running on older versions of Postgres/PostGIS - due to limited
manpower... the upgrade cycle is "slow"...
(So.. if I can argue that upgrading will prevent the assert (at least
with geometries "like" these) - then
management might escalate the priority of that effort... )
PostGIS version: "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2,
released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY RASTER"
Postgres version : "PostgreSQL 9.1.7 on x86_64-unknown-linux-gnu,
compiled by gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit"
Ubuntu 12.04.1 LTS
Script to cause assertion:
http://ge.tt/api/1/files/9F44MmP1/0/blob?download
Log File states:
select ST_Buffer( ST_Collect( ST_Intersection(zone,location) ),
0)
FROM
boundary , locations
WHERE bdy_id IN (1118508,1118498,1118497)
AND dl_id IN(843023,841992,841999,842000)
ng 10.0.20.226(52638) SELECT: RightmostEdgeFinder.cpp:77: void
geos::operation::buffer::RightmostEdgeFinder::findEdge(std::vector<geos::geomgraph::DirectedEdge*>*):
Assertion `checked>0' failed.
2014-03-10 10:50:20 EDT|15898| LOG: server process (PID 11790) was
terminated by signal 6: Aborted
2014-03-10 10:50:20 EDT|15898| LOG: terminating any other active
server processes
Removing the Buffer(...,0) above keeps these geometries from failing...
but from SVN I know we added the Buffer(...,0) to prevent an ASSERT
from a different set of geometries [2-3 months ago].
Changing the resolution to 0.000001 also avoids the crash [for these
geometries] (which is probably what we will do for now).
All suggestions welcome...
Roxanne
