[postgis-users] Loading a PostGIS dump
    Paragon Corporation
    lr at pcorp.us
    Wed Aug 26 14:52:22 PDT 2015
As I recall, I think  pg_stat_activity shows database restore work.  So I would run something like
SELECT * FROM pg_stat_activity WHERE datname='mydb';
Replacing mydb with your db.
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Brian Wilson
Sent: Wednesday, August 26, 2015 4:07 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Cc: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] Loading a PostGIS dump
Best advice ever: Listen to PAUL not to BRIAN. :-)
I was also going to say "what makes you think it stopped"? Stop is usually noisy and ends with a command prompt.
Does it load the tables then set ownership? That would be easy to fix later.
My own Q -- What would be a reasonable query to run to see if it's loading?
Brian
On Wed, Aug 26, 2015 at 12:18 PM, Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> > wrote:
The COPY command used to load tables is basically 100% silent, so it
just might have been working away. A good thing to check is 'top' to
see if the postgres process is busy using CPU. If so, it's hard at
work on your process. If not, then perhaps something is awry.
P
On Wed, Aug 26, 2015 at 12:01 PM, Lee Hachadoorian
<Lee.Hachadoorian+L at gmail.com <mailto:Lee.Hachadoorian%2BL at gmail.com> > wrote:
> New Linux machine, new PostGIS install (postgresql-9.3-postgis-2.1). I
> created DB and added extensions. Now trying to load database using
> postgis_restore.pl <http://postgis_restore.pl> . This is a large database (63GB dump, created from
> DB that was probably 600GB or more).
> The script ran for a while. Then it stopped at
>  setval
>      53
> (1 row)
> It's been hanging out there for hours now, so I assume something is
> hopelessly wrong.
> The loader created foo.dump.lst at 10:50am and I piped errors to a
> text file. Errors file shows that I did not create a user who owns one
> of the schemas. `ERROR:  role "geo_user" does not exist` appears 260
> times.
> Can I just kill the loader script with Ctrl+C? Is database
> recoverable? Should I just drop database and try again from the
> beginning? Is failure related to missing role, or if not how do I
> figure out what the error is so that I can get this to run to
> completion?
> Best,
> --Lee
> Lee Hachadoorian
> Asst Professor of Geography, Temple University
> http://geospatial.commons.gc.cuny.edu/
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Brian Wilson, GISP
@brian_32768
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150826/add9327e/attachment.html>
