[postgis-users] 2.1.8 Bug Fix Release
Greg Troxel
gdt at ir.bbn.com
Tue Jul 7 09:53:23 PDT 2015
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> Over the past three months, we have closed a number of important bugs
> that can potentially crash a back-end, so we are releasing 2.1.8
> today.
I updated pkgsrc, and 2.1.8 passes regression tests on NetBSD 6 i386
with PostgreSQL 9.3.9.
I am seeing problems with install using -u root (which fails because
pkgsrc builds/installs into a destdir as a non-root user, normally), but
I'll need to figure out what if anything should change and actually be
coherent about it. This is not new in 2.1.8.
Here's the diff of installed files. The new 2.0.7 and 2.1.7 make sense,
but I can't explain the new emergence of:
+share/postgresql/extension/postgis--${PKGVERSION}--${PKGVERSION}.sql
plus the "next" files seem funny to me. They are all the same, so this
isn't important.
Index: PLIST
RCS file: /cvsroot/pkgsrc/databases/postgresql-postgis2/PLIST,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -p -r1.3 -r1.4
--- PLIST 5 Jun 2015 13:31:39 -0000 1.3
+++ PLIST 7 Jul 2015 16:19:19 -0000 1.4
@@ -1,4 +1,4 @@
- at comment $NetBSD: PLIST,v 1.3 2015/06/05 13:31:39 gdt Exp $
+ at comment $NetBSD: PLIST,v 1.4 2015/07/07 16:19:19 gdt Exp $
bin/pgsql2shp
bin/raster2pgsql
bin/shp2pgsql
@@ -35,6 +35,7 @@ share/postgresql/extension/postgis--2.0.
share/postgresql/extension/postgis--2.0.4--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.0.5--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.0.6--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.0.7--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.1.0--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.1.0rc1--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.1.0rc2--${PKGVERSION}.sql
@@ -45,6 +46,8 @@ share/postgresql/extension/postgis--2.1.
share/postgresql/extension/postgis--2.1.4--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.1.5--${PKGVERSION}.sql
share/postgresql/extension/postgis--2.1.6--${PKGVERSION}.sql
+share/postgresql/extension/postgis--2.1.7--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis--${PKGVERSION}.sql
share/postgresql/extension/postgis--${PKGVERSION}next--${PKGVERSION}.sql
@@ -67,6 +70,8 @@ share/postgresql/extension/postgis_tiger
share/postgresql/extension/postgis_tiger_geocoder--2.1.4--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.1.5--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--2.1.6--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.1.7--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}.sql
share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}next--${PKGVERSION}.sql
@@ -89,6 +94,8 @@ share/postgresql/extension/postgis_topol
share/postgresql/extension/postgis_topology--2.1.4--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.1.5--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--2.1.6--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--2.1.7--${PKGVERSION}.sql
+share/postgresql/extension/postgis_topology--${PKGVERSION}--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}--${PKGVERSION}next.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}.sql
share/postgresql/extension/postgis_topology--${PKGVERSION}next--${PKGVERSION}.sql
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150707/fbc8f889/attachment.pgp>
