[postgis-users] ST_SummaryStats(ST_Clip(rast, geom)) with tiles
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed Jul 29 06:07:08 PDT 2015
Hi Juli,
I think you were close but made a mistake in the aggregates.
Try to split your functionality with the help of 'WITH' statements and
see if you can do the grouping in that way in a subselect.
Something like:
WITH clips AS (
SELECT p.ecoregion_cod, ST_Union(ST_Clip(r.rast,1, p.geom, true))
AS rast
FROM gis_wd.wd_ecoregiones AS p, rastertmp.prova AS r
WHERE ST_Intersects(r.rast, p.geom)
GROUP BY ecoregion_cod --now you don't have to group by the raster
result itself
SELECT p.ecoregion_co, (ST_SummaryStats(rast, 1)).* FROM clips --this
should give you the stats per ecoregion_co
best,
Tom
On 7/22/2015 2:39 PM, juli g. pausas wrote:
> Hi
> I have a raster from which I'd to compute some stats. The raster have
> with tiles, so
> SELECT (ST_SummaryStats(rast, 1)).* FROM rastertmp.prova
> -- give me the stats for each tiles
> SELECT (ST_SummaryStats(ST_Union(rast), 1)).* FROM rastertmp.prova
> -- give me the stats for all raster map, OK
> Now I'd like to intersect with a polygon map (ecoregion) and get the
> stats for each region:
> SELECT ecoregion_cod, (res).* FROM
> (SELECT p.ecoregion_cod, ST_SummaryStats(ST_Clip(r.rast,1, p.geom,
> true)) AS res
> GROUP BY ecoregion_cod, res) AS foo;
> this give me the stats for each region in each tile, but I'd like the
> overall stats, i.e. the stats for each region in the whole raster. How
> can I do it?
> Including ST_Union before clipping didn't wok ..
> ERROR: aggregate functions are not allowed in GROUP BY
> Any other way?
> The only thing I can think off is to do it 'manually' using ST_ValueCount:
> SELECT ecoregion_cod, SUM(valor * suma)/SUM(suma) AS mean, SUM(suma)
> AS n, MIN(valor) AS min, MAX(valor) AS max
> FROM
> (SELECT ecoregion_cod, (res).value AS valor, SUM((res).count) AS suma
> FROM
> (SELECT p.ecoregion_cod, ST_ValueCount(ST_Clip(r.rast,1, p.geom,
> true)) AS res
> FROM gis_wd.wd_ecoregiones AS p, rastertmp.provanet AS r
> ) AS foo
> GROUP BY ecoregion_cod, valor
> ) AS foo2
> ORDER BY ecoregion_cod;
> In this way I can compute the mean (and min, max), but I cannot
> compute StdDev from ValueCount. Is there a way?
> Thanks for any suggestion
> Regards
> Juli
> *CIDE, CSIC* | www.uv.es/jgpausas <http://www.uv.es/jgpausas> |
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150729/56ee5928/attachment.html>
