[postgis-users] Queries on partitioned table not behaving as expected
Rubio Vaughan rubio.vaughan at geodan.nl
Mon Nov 2 08:45:02 PST 2015
Dear all,
We are trying to load a large LIDAR pointcloud dataset into multiple
tables in PostGIS, using the point cloud extension. Eventually the whole
data set will consist of 1400+ tables, containing about 1 million
records each. Using a union view on all these tables would result in
terrible performance, which is why we are trying to optimize query
performance using partitioned tables. According to the documentation,
the use of partitioned tables with CHECK constraints should cause the
query planner to only scan those tables for which the CHECK constraint
matches. Excerpt from the documentation:
*18.7.4. Other Planner Options*
constraint_exclusion(enum): Controls the query planner's use of table
constraints to optimize queries. The allowed values of
constraint_exclusion are on (examine constraints for all tables), off
(never examine constraints), and partition (examine constraints only for
inheritance child tables and UNION ALL subqueries). partition is the
default setting. It is often used with inheritance and partitioned
tables to improve performance. When this parameter allows it for a
particular table, the planner compares query conditions with the table's
CHECK constraints, and omits scanning tables for which the conditions
contradict the constraints.
However, as you can see from the example query below, the indexes for
all child tables are still scanned. I would expect the query planner to
only scan table c_25gn1, which contains the queried region. Does anyone
here have experience with partitioned tables? I would be delighted to
get some pointers for figuring out this problem.
Thanks in advance for any help!
Best regards,
Rubio Vaughan
*General info:**
SELECT postgis_full_version();
"POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.0"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 2.0.1, released 2015/09/15"
LIBXML="2.9.1" LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.1.4
r12966" need upgrade) RASTER"
SHOW "constraint_exclusion";
"partition"
*The parent table:*
CREATE TABLE ahn3_pointcloud.ahn3_all
id integer NOT NULL,
pa pcpatch(7)
*One of the child tables:*
CREATE TABLE ahn3_pointcloud.c_25dn2
   id serial NOT NULL,
   pa pcpatch(7),
   CONSTRAINT c_25dn2_pkey PRIMARY KEY (id),
   CONSTRAINT check_extent CHECK (pc_intersects(pa,
st_geomfromtext('POLYGON((115000 487500,120000 487500,120000
481250,115000 481250,115000 487500))'::text, 28992)))
INHERITS (ahn3_pointcloud.ahn3_all)
*Example query:*
EXPLAIN SELECT COUNT(pa) FROM ahn3_pointcloud.ahn3_all
WHERE PC_Intersects(pa, ST_MakeEnvelope(120740,486076,121074,486292, 28992))
"Aggregate  (cost=301989.36..301989.37 rows=1 width=32)"
"  ->  Append  (cost=0.00..301248.82 rows=296216 width=32)"
"        ->  Seq Scan on ahn3_all  (cost=0.00..0.00 rows=1 width=32)"
"              Filter:
(('010300002040710000010000000500000000000000407AFD4000000000<snip>
"        ->  Bitmap Heap Scan on c_25gn1 (cost=6064.85..59546.09
rows=58574 width=32)"
"              Recheck Cond:
('010300002040710000010000000500000000000000407AFD40000<snip>
"              Filter:
_st_intersects('010300002040710000010000000500000000000000407<snip>
"              ->  Bitmap Index Scan on c_25gn1_idx (cost=0.00..6050.20
rows=175722 width=0)"
"                    Index Cond:
('010300002040710000010000000500000000000000407AFD4<snip>
"        ->  Bitmap Heap Scan on c_30fz1 (cost=7990.39..77907.99
rows=76576 width=32)"
"              Recheck Cond:
"              Filter:
"              ->  Bitmap Index Scan on c_30fz1_idx (cost=0.00..7971.24
rows=229727 width=0)"
"                    Index Cond:
"        ->  Bitmap Heap Scan on c_30fz2 (cost=7393.57..71499.52
rows=70210 width=32)"
"              Recheck Cond:
"              Filter:
"              ->  Bitmap Index Scan on c_30fz2_idx (cost=0.00..7376.02
rows=210631 width=0)"
"                    Index Cond:
"        ->  Bitmap Heap Scan on c_25ez1 (cost=2624.69..26079.63
rows=25688 width=32)"
"              Recheck Cond:
"              Filter:
"              ->  Bitmap Index Scan on c_25ez1_idx (cost=0.00..2618.27
rows=77064 width=0)"
"                    Index Cond:
"        ->  Bitmap Heap Scan on c_25dn2 (cost=6714.83..66215.58
rows=65167 width=32)"
"              Recheck Cond:
"              Filter:
"              ->  Bitmap Index Scan on c_25dn2_idx (cost=0.00..6698.54
rows=195500 width=0)"
"                    Index Cond:
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151102/235fc187/attachment.html>
