[postgis-users] Queries on partitioned table not behaving as expected
Rémi Cura
remi.cura at gmail.com
Tue Nov 3 02:45:41 PST 2015
Hey,
i tried to do exactly this,
as it is currently the only thing preventing postgis (thus pgpointcloud) to
scale well.
No strategy succeded, postgres mailing list was also clueless.
So un short no way to use partitionning without extensive tricks with
postgres rules.
Instead, it is very simple to design a table holding extent of each lidar
tables, then a fonction performing the check and creating the union
statment on the fly.
Maybe you can even use rule on father table so this mechanism is totally
transparent to the user.
Please keep us posted !
Cheers,
Remic
Le 3 nov. 2015 05:47, "Andy Colson" <andy at squeakycode.net> a écrit :
> Yep, +1 do all this.
> Additionally: select performance is not a reason to use partitioned
> tables. Its only update/delete performance that's increased.
> Ok, _some_ selects might be faster with partitions, but I'd bet not
> indexed select statements. You'd have to benchmark it.
> If you really want 1400+ tables you might be able to write yourself a
> function that figures out what table/tables to query and generates a sql
> statement dynamically.
> Like from the docs:
> http://www.postgresql.org/docs/9.4/static/plpgsql-statements.html#PLPGSQL-STATEMENTS-EXECUTING-DYN
> (sorry, watch the word wrap)
> -Andy
> On 11/2/2015 12:53 PM, Nicolas Ribot wrote:
>> Hi,
>> AFAIU, the restriction on partitioned tables is even bigger. From PG doc
>> http://www.postgresql.org/docs/current/interactive/ddl-partitioning.html#DDL-PARTITIONING-CONSTRAINT-EXCLUSION
>> "The following caveats apply to constraint exclusion:
>> Constraint exclusion only works when the query's WHERE clause
>> contains constants (or externally supplied parameters). For example,
>> a comparison against a non-immutable function such
>> as|CURRENT_TIMESTAMP| cannot be optimized, since the planner cannot
>> know which partition the function value might fall into at run time.
>> Using a subquery to provide values won't trigger the constraint exclusion.
>> One solution could be an anonymous block or a function to explicitly
>> write query with constant values got from a previous query.
>> Rubio, take also care that a lot of partitioned tables is not
>> recommended by Pg doc:
>> "All constraints on all partitions of the master table are examined
>> during constraint exclusion, so large numbers of partitions are likely
>> to increase query planning time considerably. Partitioning using these
>> techniques will work well with up to perhaps a hundred partitions; don't
>> try to use many thousands of partitions."
>> I would go for a smaller set of bigger tables (10's millions rows or so).
>> Nicolas
>> On 2 November 2015 at 18:28, Bborie Park <dustymugs at gmail.com
>> <mailto:dustymugs at gmail.com>> wrote:
>> That check constraint is not going to help you as it is too
>> complicated for the partitioning task. I don't believe the
>> partitioning constraint can be functional but needs to be simpler
>> and built upon a basic data type...
>> Something like...
>> CREATE TABLE max_extent AS (
>> id integer PRIMARY KEY,
>> geom geometry(POLYGON)
>> And then the parent/partition tables had a reference to pc_extent...
>> CREATE TABLE ahn3_pointcloud.ahn3_all
>> id integer NOT NULL,
>> pa pcpatch(7),
>> max_extent_id integer
>> Then your queries become...
>> WITH max_extents AS (
>> SELECT
>> id
>> FROM max_extent
>> WHERE PC_Intersects(geom,
>> ST_MakeEnvelope(120740,486076,121074,486292, 28992))
>> SELECT
>> FROM ahn3_all
>> JOIN max_extents
>> ON ahn3_all.max_extent_id = max_extents.id <http://max_extents.id>
>> -bborie
>> On Mon, Nov 2, 2015 at 8:45 AM, Rubio Vaughan
>> <rubio.vaughan at geodan.nl <mailto:rubio.vaughan at geodan.nl>> wrote:
>> Dear all,
>> We are trying to load a large LIDAR pointcloud dataset into
>> multiple tables in PostGIS, using the point cloud extension.
>> Eventually the whole data set will consist of 1400+ tables,
>> containing about 1 million records each. Using a union view on
>> all these tables would result in terrible performance, which is
>> why we are trying to optimize query performance using
>> partitioned tables. According to the documentation, the use of
>> partitioned tables with CHECK constraints should cause the query
>> planner to only scan those tables for which the CHECK constraint
>> matches. Excerpt from the documentation:
>> *18.7.4. Other Planner Options*
>> constraint_exclusion(enum): Controls the query planner's use of
>> table constraints to optimize queries. The allowed values of
>> constraint_exclusion are on (examine constraints for all
>> tables), off (never examine constraints), and partition (examine
>> constraints only for inheritance child tables and UNION ALL
>> subqueries). partition is the default setting. It is often used
>> with inheritance and partitioned tables to improve performance.
>> When this parameter allows it for a particular table, the
>> planner compares query conditions with the table's CHECK
>> constraints, and omits scanning tables for which the conditions
>> contradict the constraints.
>> However, as you can see from the example query below, the
>> indexes for all child tables are still scanned. I would expect
>> the query planner to only scan table c_25gn1, which contains the
>> queried region. Does anyone here have experience with
>> partitioned tables? I would be delighted to get some pointers
>> for figuring out this problem.
>> Thanks in advance for any help!
>> Best regards,
>> Rubio Vaughan
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151103/143feb52/attachment.html>
