[postgis-users] I am probably being stupid but I cannot get my rasters to display using QGIS
Christian Yrrman
yrrman at gmail.com
Sat Nov 7 06:13:33 PST 2015
Hi Darrel,
did you save the password for the db connection in qgis' dbmanager? If not
you'll get the same error.. (i.e. you are not being prompted for a password
again)
Also, there are two ways of adding a raster table to qgis with dbmanager:
1. by right-clicking "Add to Canvas" and
2. by drag+dropping it to the layers panel.
Method (2) gives more meaningful error messages.
Good luck!!
Chris
On Sat, Nov 7, 2015 at 2:23 PM, Darrel Maddy <darrel.maddy at newcastle.ac.uk>
wrote:
> Dear Regina,
> Many thanks for trying to help this is much appreciated.
> I replaced the function as directed (at least I believe I did!). I removed
> the table constraints as directed and then created the view as directed.
> This was done on my laptop so the names are slightly different as I
> inserted the data table into the ch01 schema.
> Unfortunately when I try to add the view or the raster directly in QGIS I
> get :
> 2015-11-07T13:08:34 0 QGIS starting...
> 2015-11-07T13:08:35 0 Python support ENABLED :-)
> 2015-11-07T13:08:49 0 Application state:
> QGIS_PREFIX_PATH env var: C:/PROGRA~1/QGISPI~1/apps/qgis
> Prefix: C:/PROGRA~1/QGISPI~1/apps/qgis
> Plugin Path: C:/PROGRA~1/QGISPI~1/apps/qgis/plugins
> Package Data Path: C:/PROGRA~1/QGISPI~1/apps/qgis/.
> Active Theme Name: default
> Active Theme Path: :/images/themes/default/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: C:/PROGRA~1/QGISPI~1/apps/qgis/./svg/
> C:/Users/ndm12/.qgis2//svg/
> User DB Path: C:/PROGRA~1/QGISPI~1/apps/qgis/./resources/qgis.db
> 2015-11-07T13:08:49 0 QGIS Ready!
> 2015-11-07T13:09:32 1 PG: dbname=postgis_in_action port=5433 mode=2
> schema=ch01 column=rast table=testrast is an invalid layer - not loaded
> 2015-11-07T13:18:50 1 PG: dbname=postgis_in_action port=5433 mode=2
> schema=ch01 column=rast table=test is an invalid layer - not loaded
> This is curious as the original tif file loads without error into QGIS
> directly.
> Running your query returns
> r_table_catalog r_table_schema r_table_name
> r_raster_column srid scale_x
> scale_y blocksize_x blocksize_y
> same_alignment regular_blocking
> num_bands pixel_types
> nodata_values out_db extent spatial_index
> postgis_in_action ch01 test rast
> 27700 None None 2928
> 2960 True False 1
> [u'64BF'] [-9999.0] [False]
> 0103000020346C00000100000005000000E0CCCCCCB1D517418066666692BE0541E0CCCCCCB1D517418066666692F80C41E0CCCCCCB1681B418066666692F80C41E0CCCCCCB1681B418066666692BE0541E0CCCCCCB1D517418066666692BE0541
> True
> postgis_in_action ch01 testrast rast
> 0 None None None
> None False False None
> None None None None False
> Darrel
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151107/df0b2b0b/attachment.html>
