[postgis-users] restore problem
Darrel Maddy
darrel.maddy at newcastle.ac.uk
Tue Nov 10 13:33:44 PST 2015
Hi Tim,
I am on windows and using the latest version 2.2 of postgis (and postgresql 9.4). My original databases do not have pg_raster as an extension – I am assuming that is not required now?
Darrel
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tim Sutton
Sent: 10 November 2015 21:30
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] restore problem
Hi
On 10 Nov 2015, at 23:26, Darrel Maddy <darrel.maddy at newcastle.ac.uk<mailto:darrel.maddy at newcastle.ac.uk>> wrote:
Dear Tim,
Thanks for this suggestion. I had assumed that the extensions were part of the backup as they appear on the manifest and indeed they appear in the restored database.
Alas this made no difference – I just tried it, creating the extension first before restore and I get exactly the same error.
And is pg_raster also installed in the target db before doing the restore? I don’t know if it is considered best practice by the postgis guru’s, but I usually install any extensions before doing a restore to deal with version differences between source and target systems gracefully...
Regards
Tim
Darrel
Sent: 10 November 2015 21:15
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Hi
On 10 Nov 2015, at 23:11, Darrel Maddy <darrel.maddy at newcastle.ac.uk<mailto:darrel.maddy at newcastle.ac.uk>> wrote:
Dear all,
Like many here I suspect I want to keep a copy of my main databases held on my workstation, on my laptop. I used PgAdmin to backup the databases concerned (the backup files look about the size I was expecting) but restore on my laptop did not successfully complete. All my shp file tables restored without issues but my raster tables (these are tiled rasters) would not. Looking at the error in the restore window of PgAdmin this appears to be a problem with a function/constraint.
pg_restore: processing data for table "dems"
pg_restore: [archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 3459; 0 94054 TABLE DATA dems postgres
pg_restore: [archiver (db)] COPY failed for table "dems": ERROR: function st_bandmetadata(public.raster, integer[]) does not exist
LINE 1: SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1, ARRAY[]::int[]);
CONTEXT: SQL function "_raster_constraint_pixel_types" during inlining
COPY dems, line 1: "1 0100000100000000000000344000000000000034C0E0CCCCCCB1D517418066666692F80C41000000000000000000000000..."
I did a quick search and found some old chatter on this issue but from the messages I read I would have expected this issue to have been cleared up in postgis 2 .
Obviously I cannot contemplate having mission critical data in a database which does not backup/restore correctly so I am assuming there is a fix which avoids this issue or there is another way to make a copy of the database for transfer elsewhere?
Have you enabled the PostGIS extension on the destination database before attempting to restore?
Regards
Tim
Once again any help would be gratefully received.
Best wishes
Darrel
ps. Apologies for the string of questions I have asked lately – I will go silent once more shortly as I must move on to other things.
postgis-users mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-users
<image001.png>
Tim Sutton
Visit http://kartoza.com<http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net<http://freenode.net/>
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
[cid:image001.png at 01D11BFF.7AE714F0]
Tim Sutton
Visit http://kartoza.com to find out about open source:
* GIS Training
Skype: timlinux Irc: timlinux on #qgis at freenode.net<http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151110/55e8d6b9/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151110/55e8d6b9/attachment.png>
