[postgis-users] restore problem
Bborie Park
dustymugs at gmail.com
Tue Nov 10 13:56:59 PST 2015
Given that the core problem has to do with the restore process'
search_path, no amount of advice will help you get around the restrictions
in place with the restore process without jumping into that process.
In pgAdmin, you can check the boxes "Pre-data" and "Data" of the "Restore
Options #1" tab. This won't restore the post-data portion of the backup as
restoring post-data should be causing your error.
You could also try unchecking the box "Exit On Error" of the "Restore
Options #2" tab.
-bborie
On Tue, Nov 10, 2015 at 1:29 PM, Darrel Maddy <darrel.maddy at newcastle.ac.uk>
wrote:
> Dear Bborie,
> Yikes – that makes little sense to me. I am new to both postgres and
> postgis and would have hoped that backup and restore would have been simple
> push-button exercise!
> As I am using PgAdmin I have no idea how to follow your instructions L
> Anyone care to give me an idiots guide?
> Sorry
> Darrel
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Bborie Park
> *Sent:* 10 November 2015 21:22
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] restore problem
> This problem arises because PostgreSQL sets the search path during the
> restore process. Unfortunately, the search path is quite restrictive.
> You should be able to do your restore in three sections using pg_restore's
> --section flag.
> The error looks like it has to be the post-data section, which you should
> output to a text file, change the "SET search_path" statements and then run
> through psql.
> -bborie
> On Tue, Nov 10, 2015 at 1:11 PM, Darrel Maddy <
> darrel.maddy at newcastle.ac.uk> wrote:
> Dear all,
> Like many here I suspect I want to keep a copy of my main databases held
> on my workstation, on my laptop. I used PgAdmin to backup the databases
> concerned (the backup files look about the size I was expecting) but
> restore on my laptop did not successfully complete. All my shp file tables
> restored without issues but my raster tables (these are tiled rasters)
> would not. Looking at the error in the restore window of PgAdmin this
> appears to be a problem with a function/constraint.
> pg_restore: processing data for table "dems"
> pg_restore: [archiver (db)] Error while PROCESSING TOC:
> pg_restore: [archiver (db)] Error from TOC entry 3459; 0 94054 TABLE DATA
> dems postgres
> pg_restore: [archiver (db)] COPY failed for table "dems": ERROR: function
> st_bandmetadata(public.raster, integer[]) does not exist
> LINE 1: SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1...
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> QUERY: SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1,
> ARRAY[]::int[]);
> CONTEXT: SQL function "_raster_constraint_pixel_types" during inlining
> COPY dems, line 1: "1
> 0100000100000000000000344000000000000034C0E0CCCCCCB1D517418066666692F80C41000000000000000000000000..."
> I did a quick search and found some old chatter on this issue but from the
> messages I read I would have expected this issue to have been cleared up in
> postgis 2 .
> Obviously I cannot contemplate having mission critical data in a database
> which does not backup/restore correctly so I am assuming there is a fix
> which avoids this issue or there is another way to make a copy of the
> database for transfer elsewhere?
> Once again any help would be gratefully received.
> Best wishes
> Darrel
> ps. Apologies for the string of questions I have asked lately – I will
> go silent once more shortly as I must move on to other things.
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151110/aeb42ba2/attachment.html>
