[postgis-users] Exception Handling in Postgis function
ranjitsaurav ranjitsaurav at gmail.com
Fri Nov 13 18:17:56 PST 2015
Hi
I am new in the postgressql and postgis. I am trying to using the exception
handling for
the postgis function. The query is as follows.
"SELECT topology.AddEdge('road_topology', ST_GeomFromText(l.linestring,
4326)) As edgeid
from
(SELECT ST_AsText(geom) as linestring FROM public.clip_linestring) as l;"
This query is showing error as follows
ERROR:  Edge intersects (not on endpoints) with existing edge 162 at or near
point POINT(100.3812061 13.6915724)
I would like to implement exception handling so that I could know from which
line of table "clip_linestring" this error is coming. I would like to know
the row in the table from which the error is being generated.
How do I use the exception handling for these kind of issue.
Thank you.
Regards,
Saurav Ranjit
View this message in context: http://postgis.17.x6.nabble.com/Exception-Handling-in-Postgis-function-tp5009311.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
