[postgis-users] Exception Handling in Postgis function
Rémi Cura remi.cura at gmail.com
Sun Nov 15 12:38:52 PST 2015
Hey,
you are probably using the wrong function,
you may want to use
http://postgis.net/docs/manual-dev/TopoGeo_AddLineString.html
For exception, this is pretty easy using plpgsql
http://www.postgresql.org/docs/current/static/plpgsql-control-structures.html
40.6.6
Cheers,
RémiC
2015-11-14 3:17 GMT+01:00 ranjitsaurav <ranjitsaurav at gmail.com>:
> Hi
> I am new in the postgressql and postgis. I am trying to using the exception
> handling for
> the postgis function. The query is as follows.
> "SELECT topology.AddEdge('road_topology', ST_GeomFromText(l.linestring,
> 4326)) As edgeid
> from
> (SELECT ST_AsText(geom) as linestring FROM public.clip_linestring) as l;"
> This query is showing error as follows
> ERROR:  Edge intersects (not on endpoints) with existing edge 162 at or
> near
> point POINT(100.3812061 13.6915724)
> I would like to implement exception handling so that I could know from
> which
> line of table "clip_linestring" this error is coming. I would like to know
> the row in the table from which the error is being generated.
> How do I use the exception handling for these kind of issue.
> Thank you.
> Regards,
> Saurav Ranjit
> http://postgis.17.x6.nabble.com/Exception-Handling-in-Postgis-function-tp5009311.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151115/e07630e9/attachment.html>
