[postgis-users] prj2esri.org
Andrea Aime
andrea.aime at geo-solutions.it
Tue Jan 12 01:17:49 PST 2016
On Tue, Jan 12, 2016 at 3:52 AM, Clifford Snow <clifford at snowandsnow.us>
wrote:
> I'm looking for code to suggest to QGIS developers to use. Right now QGIS
> doesn't recognize Washington State Plane North/South. And besides, I'm
> curious how it's accomplished. Doing it by hand resulted in me picking the
> wrong match!
I wrote the first version of site several years ago, it's a simple
application of the GeoTools referencing subsystem, backed by the EPSG
database.
Not sure how it works today, but I can tell you how it used to work back
then.
When you paste a PRJ, first it parses it and tries to perform a match
against the official EPSG database, by first making an indexed
search by projection name and a few other params, falling on a brute force
scan and compare if the first does not match.
If not even that works, then it has a secondary Lucene index with all
projections WKTs stored inside, and it will do a
text based search against it, hoping to find something similar (aka "shot
in the dark").
Hope this helps
Cheers
Andrea
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160112/d2963d08/attachment.html>
