[postgis-users] PostGIS Out-DB Raster Not Behaving As Expected
Regina Obe
lr at pcorp.us
Mon Apr 10 12:31:40 PDT 2017
You should also check the following queries
SELECT r_table_name, r_raster_column, out_db FROM raster_columns;
Out_db should be true for all your bands for the specific table and as Jorge mentioned, you shouldn't see any over view tables (which start with o_..{table}.
I believe QGIS internally tries to use over view tables to speed things up, so it's possible it's using an overview table instead of the main outdb table if you are zoomed out enough.
For outdb, querying the meta data of the raster will tell you the path if it's an outdb. Replace nj_ned with your table name.
SELECT t.rid, (md).isoutdb, (md).path
FROM nj_ned AS t, ST_BandMetaData(t.rast) AS md
limit 1;
Hope that helps,
Regina
http://postgis.us
http://postgis.net
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jorge Gustavo Rocha
Sent: Monday, April 10, 2017 2:14 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] PostGIS Out-DB Raster Not Behaving As Expected
According to the documentation [1], if you add the option -l (like -l
2,4,8,16 ), the overviews are created in the database, even if you use the -R option.
But since you did not use the -l option, I don't know how you can see the images.
Can you check the layer properties in QGIS? Are any pyramids available or not?
Regards,
Jorge
s 16:52 de 10-04-2017, Osahon Oduware escreveu:
> Hi All,
> I created an out-db raster using the following syntax:
> raster2pgsql -s {srid} -c -R -I -C -F -t auto {absolute_file_path}
> public.{table} | psql -h {host} -p {port} -d {database} -U {user}
> The table was created successfully. I wanted to confirm that the
> actual file is being read from the location in the filesystem by
> performing the following steps:
> 1) I moved the raster file to a different location.
> 2) I opened QGIS and attempted to load the raster from PostGIS table.
> I was surprised that QGIS could load the file. *How is this possible
> when the actual raster data is not stored in the database table?*
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
J. Gustavo
Jorge Gustavo Rocha
Departamento de Inform tica
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
M vel: +351 910333888
skype: nabocudnosor
