[postgis-users] Restore a raster dump from PostGIS 2.1.0 to PostGIS 2.3.0
Shane StClair
shane at axiomdatascience.com
Tue May 2 17:40:22 PDT 2017
Hi Regina,
Thanks so much for the quick response, that did the trick!
-Shane
On Tue, May 2, 2017 at 1:53 PM Regina Obe <lr at pcorp.us> wrote:
> Shane,
> I've ticketed this issue here: https://trac.osgeo.org/postgis/ticket/3750
> Most of these issues related to restore were fixed in PostGIS 2.3, but
> looks like you found a missed spot.
> To fix, you should have a folder in your postgresql install
> share/extension with a file called postgis.sql
> Search for $1 @ $2
> Should be around line 4057
> Change that to:
> $1 OPERATOR(@extschema at .@) $2
> And then try to reinstall your backup in a clean database.
> Let me know if you still run into issues.
> Thanks,
> Regina
> PostGIS PSC Member
> http://www.postgis.us
> http://postgis.net
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shane StClair
> *Sent:* Tuesday, May 02, 2017 3:55 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Restore a raster dump from PostGIS 2.1.0
> to PostGIS 2.3.0
> Was a solution to this problem ever discovered? I'm running into exactly
> the same problem (backup from PostGIS 2.1 with raster tables can't be
> restored to PostGIS 2.3).
> HINT: No operator matches the given name and argument type(s). You might
> need to add explicit type casts.
> QUERY: SELECT $1 @ $2 AND public._ST_CoveredBy($1,$2)
> CONTEXT: SQL function "st_coveredby" during inlining
> COPY coei_166_3857, line 1: "1
> 010000010091C9D81F26AAE94091C9D81F26AAE9C082B6A532F81B73C103DAD0FE58846041000000000000000000000000..."
> pg_restore: [archiver (db)] Error from TOC entry 187538; 0 223203 TABLE
> DATA coei_196_3857 asdf
> pg_restore: [archiver (db)] COPY failed for table "coei_196_3857": ERROR:
> operator does not exist: public.geometry @ public.geometry
> LINE 1: SELECT $1 @ $2 AND public._ST_CoveredBy($1,$2)
> On Fri, Nov 25, 2016 at 6:48 AM Cedric Duprez <Cedric.Duprez at ign.fr>
> wrote:
> Sorry, I thought I had installed PostGIS 2.1 on my backup server, but it
> is 2.3 that has been finally installed.
> I don't understand how that could be.
> The server is on Debian Jessie, and I did the following packages
> installation:
> apt-get update && apt-get install -y postgresql-9.3 postgresql-client-9.3
> postgresql-contrib-9.3 postgresql-server-dev-9.3 && \
> apt-get install -y gdal-bin libgdal-dev && \
> apt-get install -y postgresql-9.3-postgis-2.1
> Why do I get the 2.3 version of PostGIS installed? How can I downgrade to
> 2.1?
> Thanks for you help.
> Regards,
> Cedric
> Hi,
> Still same issue with two servers having the same configuration.
> Regards,
> Cedric
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170503/42c17550/attachment.html>
