[postgis-users] Self-intersecting polygon gives ST_IsSimple=true
Jukka Rahkonen
jukka.rahkonen at latuviitta.fi
Fri May 5 00:28:03 PDT 2017
I do not understand this:
select ST_IsValid(
ST_GeomFromText(
'POLYGON (( 320 620, 460 620, 460 500, 320 620, 320 500, 180 500, 180
620, 320 620 ))'
Result: "f".
select ST_IsValidReason(
ST_GeomFromText(
620, 320 620 ))'
Result: "Ring Self-intersection[320 620]"
select ST_IsSimple(
ST_GeomFromText(
620, 320 620 ))'
Result: "t"
Shouldn't ST_IsSimple return "false"? OpenJUMP reports that this polygon
is "Not Simple Geometry"
I tried PostGIS versions 2.1 and 2.3, both versions give "true".
-Jukka Rahkonen-
