[postgis-users] Newbie - Help with PGRouting
Daniel Kastl daniel at georepublic.de
Sun May 21 16:46:00 PDT 2017
Hi Benjie,
Which URL are you referring to?
It's good to get some feedback like this. Maybe we can show the essential
information prominently.
What you need to install depends mainly on your operating system.
Are you using Windows?
Best regards,
Daniel
On Mon, May 22, 2017 at 5:30 AM, Benjamin Orpilla <
Benjamin.Orpilla at downer.co.nz> wrote:
> Hi all,
> I am new at using PostGreSQL/PostGIS. I am wanting to run a routing
> analysis and found the documentation at the PGRouting site with links to
> downloads here. However, I am overwhelmed by the number of build and what
> to actually download and install on my machine. Any guidance would be much
> appreciated.
> Cheers,
> Benjie
> *Benjamin Orpilla*
> Asset Information Manager
> New Zealand
> <http://www.downergroup.co.nz/>
> *M* | +64277068599 <+64%2027%20706%208599>
> *E* | Benjamin.Orpilla at downer.co.nz
> 133 Main South Rd
> Dunedin
> www.downercareers.co.nz
> *Think before you print *
> *Note:This message is for the named person's use only. It may contain confidential, proprietary or legally privileged information.  If you receive this message in error, please immediately delete it and all copies of it from your system, destroy any hard copies of it and notify the sender. You must not, directly or indirectly, use, disclose,distribute, print, or copy any part of this message if you are not the intended recipient. No confidentiality or privilege is waived or lost by any such mis-transmission or error. Downer reserves the right to monitor all e-mail communications through its networks. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to state them to be the views of any such entity. Downer includes Downer New Zealand Limited and Hawkins 2017 Limited and their related and associated companies.*
> This email has been filtered by SMX. For more information visit
> smxemail.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170522/0127ac84/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170522/0127ac84/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170522/0127ac84/attachment.jpg>
