[postgis-users] Newbie - Help with PGRouting
Joshua Chamberlain
josh at zephyri.co
Sun May 21 16:53:23 PDT 2017
On Sun, May 21, 2017 at 1:30 PM, Benjamin Orpilla <
Benjamin.Orpilla at downer.co.nz> wrote:
> Hi all,
> I am new at using PostGreSQL/PostGIS. I am wanting to run a routing
> analysis and found the documentation at the PGRouting site with links to
> downloads here. However, I am overwhelmed by the number of build and what
> to actually download and install on my machine. Any guidance would be much
> appreciated.
> Cheers,
> Benjie
Are you familiar with Docker? In my opinion, that's the easiest way to get
started with PostGIS and pgRouting. Using the starefossen/pgrouting image,
start Postgres like so:
$ docker run --name pg -e POSTGRES_PASSWORD=mysecretpassword -d
That will run in the background, at which point you can connect using psql
like this:
$ docker exec -it pg psql -U postgres
You won't have any data in your database, but PostGIS+pgRouting are
otherwise ready to go. Do you have a dataset you want to use?
(Of course if you don't already know Docker, this might just make the
rabbit hole deeper.)
Regards,
Joshua Chamberlain
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170521/f6b3c12c/attachment.html>
