[postgis-users] identifing duplicate line features (with different draw directions0
Richard Greenwood
richard.greenwood at gmail.com
Tue May 23 17:14:39 PDT 2017
Have you thought about using a topology? Seems like that's sort of what
you're after.
On May 19, 2017 11:55 AM, "Basques, Bob (CI-StPaul)" <
bob.basques at ci.stpaul.mn.us> wrote:
> I’m trying to remove all duplicated parcel edges from an exploded parcel
> dataset. I have a set of 2 point line segments and I’ve been able to find
> the geom duplicates ok witha window partition, but the number was really
> low. Upon examining the data more closely, I figured out that the majoirty
> of the duplicates are indeed the same line, but the end points are swapped
> around, so they appear in the window as different feature.
> Anyone have a SQL chunk/function that I should look at to get to this
> matching of spatial location?
> Thanks
> bobb
> "Be nice to people on your way up because you meet them on your way down."
> - Jimmy Durante
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170523/b599ce94/attachment.html>
