[postgis-users] 'postgis.backend' is already set
Arnaud L.
arnaud.listes at codata.eu
Tue May 30 04:43:07 PDT 2017
Le 30/05/2017 à 10:45, Regina Obe a écrit :
> It's a symptom that you have a mix of two PostGIS libraries in your db.
I think you found the problem. I had two databases in my cluster. One
was OK but the other one was indeed "legacy enabled".
I had to run uninstall_legacy.sql first, then the new legacy.sql.
Thanks a lot !
Arnaud
