[postgis-users] Problems creating postgis extension
Martin Moore martin.moore at avbrief.com
Tue May 30 12:55:58 PDT 2017
Didn’t have libproj-dev  - Now added.
ii  libgeo-proj4-perl                      1.05-1+b1                            amd64        PROJ.4 library for cartographic projections
ii  libproj-dev                            4.8.0-5                              amd64        Cartographic projection library (development files)
ii  libproj0                               4.8.0-5                              amd64        Cartographic projection library
ii  proj-bin                               4.8.0-5                              amd64        Cartographic projection library (tools)
ii  proj-data                              4.8.0-5                              amd64        Cartographic projection filter and library (datum package)
On 30/05/2017, 20:51, "postgis-users on behalf of Stephen Woodbridge" <postgis-users-bounces at lists.osgeo.org on behalf of woodbri at swoodbridge.com> wrote:
    I have the following installed:
    $ apt-show-versions | grep proj
    libproj-dev:amd64 4.8.0-3~precise2 newer than version in archive
    libproj0:amd64 4.8.0-3~precise2 newer than version in archive
    proj-bin:amd64 4.8.0-3~precise2 newer than version in archive
    proj-data:amd64 4.8.0-3~precise2 newer than version in archive
    On 5/30/2017 3:42 PM, Martin Moore wrote:
    > ld.so.conf.d# ldd /usr/lib/postgresql/9.6/lib/postgis_topology-2.3.so
    > 	linux-vdso.so.1 (0x00007ffe80def000)
    > 	libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007f267ac1f000)
    > 	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f267a874000)
    > 	libgeos-3.4.2.so => /usr/lib/libgeos-3.4.2.so (0x00007f267a4cc000)
    > 	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f267a1c1000)
    > 	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2679ec0000)
    > 	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2679ca9000)
    > 	/lib64/ld-linux-x86-64.so.2 (0x000055fafb1f0000)
    > ld.so.conf.d# ldd /usr/lib/postgresql/9.6/lib/postgis-2.3.so
    > 	linux-vdso.so.1 (0x00007ffd42f59000)
    > 	liblwgeom-2.3.so.0 => /usr/lib/liblwgeom-2.3.so.0 (0x00007f2991122000)
    > 	libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007f2990efb000)
    > 	libproj.so.0 => /usr/local/lib/libproj.so.0 (0x00007f2990cb9000)
    > 	libjson-c.so.2 => /lib/x86_64-linux-gnu/libjson-c.so.2 (0x00007f2990aae000)
    > 	libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2 (0x00007f2990747000)
    > 	libSFCGAL.so.1 => /usr/lib/x86_64-linux-gnu/libSFCGAL.so.1 (0x00007f298fd08000)
    > 	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f298f95d000)
    > 	libgeos-3.4.2.so => /usr/lib/libgeos-3.4.2.so (0x00007f298f5b6000)
    > 	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f298f2aa000)
    > 	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f298efa9000)
    > 	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f298ed93000)
    > 	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f298eb8e000)
    > 	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f298e973000)
    > 	liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f298e750000)
    > 	libCGAL.so.10 => /usr/lib/libCGAL.so.10 (0x00007f298e525000)
    > 	libCGAL_Core.so.10 => /usr/lib/libCGAL_Core.so.10 (0x00007f298e2ec000)
    > 	libmpfr.so.4 => /usr/lib/x86_64-linux-gnu/libmpfr.so.4 (0x00007f298e089000)
    > 	libgmp.so.10 => /usr/lib/x86_64-linux-gnu/libgmp.so.10 (0x00007f298de05000)
    > 	libosgDB.so.100 => /usr/lib/x86_64-linux-gnu/libosgDB.so.100 (0x00007f298daec000)
    > 	libosgUtil.so.100 => /usr/lib/x86_64-linux-gnu/libosgUtil.so.100 (0x00007f298d712000)
    > 	libosg.so.100 => /usr/lib/x86_64-linux-gnu/libosg.so.100 (0x00007f298d210000)
    > 	libOpenThreads.so.20 => /usr/lib/x86_64-linux-gnu/libOpenThreads.so.20 (0x00007f298d008000)
    > 	libboost_program_options.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_program_options.so.1.55.0 (0x00007f298cd90000)
    > 	libboost_chrono.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_chrono.so.1.55.0 (0x00007f298cb87000)
    > 	libboost_filesystem.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_filesystem.so.1.55.0 (0x00007f298c96f000)
    > 	libboost_timer.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_timer.so.1.55.0 (0x00007f298c76a000)
    > 	libboost_unit_test_framework.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_unit_test_framework.so.1.55.0 (0x00007f298c4bb000)
    > 	libboost_date_time.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_date_time.so.1.55.0 (0x00007f298c2a9000)
    > 	libboost_thread.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.55.0 (0x00007f298c08e000)
    > 	libboost_system.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_system.so.1.55.0 (0x00007f298be89000)
    > 	libboost_serialization.so.1.55.0 => /usr/lib/x86_64-linux-gnu/libboost_serialization.so.1.55.0 (0x00007f298bc17000)
    > 	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f298b9fa000)
    > 	/lib64/ld-linux-x86-64.so.2 (0x0000563ba1460000)
    > 	libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f298b75f000)
    > 	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f298b557000)
    > 	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f298b32d000)
    > 	libglapi.so.0 => /usr/lib/x86_64-linux-gnu/libglapi.so.0 (0x00007f298b103000)
    > 	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f298aef0000)
    > 	libXdamage.so.1 => /usr/lib/x86_64-linux-gnu/libXdamage.so.1 (0x00007f298aced000)
    > 	libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007f298aae7000)
    > 	libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f298a8e4000)
    > 	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f298a5a1000)
    > 	libxcb-glx.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0 (0x00007f298a388000)
    > 	libxcb-dri2.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0 (0x00007f298a182000)
    > 	libxcb-dri3.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0 (0x00007f2989f7f000)
    > 	libxcb-present.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-present.so.0 (0x00007f2989d7c000)
    > 	libxcb-sync.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f2989b74000)
    > 	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f2989952000)
    > 	libxshmfence.so.1 => /usr/lib/x86_64-linux-gnu/libxshmfence.so.1 (0x00007f2989750000)
    > 	libXxf86vm.so.1 => /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007f2989549000)
    > 	libdrm.so.2 => /usr/lib/x86_64-linux-gnu/libdrm.so.2 (0x00007f298933c000)
    > 	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f2989137000)
    > 	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f2988f32000)
    > On 30/05/2017, 20:39, "postgis-users on behalf of Stephen Woodbridge" <postgis-users-bounces at lists.osgeo.org on behalf of woodbri at swoodbridge.com> wrote:
    >      What does ldd say for your library. I'm on Ubuntu and had installed pg
    >      9.6 yet, but for 9.5 I have this:
    >      $ ldd /usr/lib/postgresql/9.5/lib/postgis_topology-2.3.so
    >               linux-vdso.so.1 =>  (0x00007ffdb19fb000)
    >               libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007f61b6e3c000)
    >               libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f61b6a74000)
    >               libgeos-3.4.2.so => /usr/lib/libgeos-3.4.2.so (0x00007f61b66ef000)
    >      (0x00007f61b63eb000)
    >      (0x00007f61b61d5000)
    >               /lib64/ld-linux-x86-64.so.2 (0x00007f61b72d7000)
    >               libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f61b5ece000)
    >      On 5/30/2017 3:34 PM, Stephen Woodbridge wrote:
    >      > On 5/30/2017 3:22 PM, Martin Moore wrote:
    >      >> Thanks Steve – nothing returned.
    >      >> I’m guessing that’s wrong!
    >      > No it doesn't return anything. It just makes sure the library is known
    >      > to the dynamic loader. Hmm, I reread your message, you are missing a
    >      > symbol, so it found the library ok.
    >      > This sounds like a packaging issue of some kind. You should make sure
    >      > that you are getting proj4, postgresql and postgis all from the same
    >      > repository and not mixing and matching.
    >      > -Steve
    >      >> On 30/05/2017, 20:19, "postgis-users on behalf of Stephen Woodbridge"
    >      >>      Try:
    >      >>      sudo ldconfig
    >      >>      and see if the helps.
    >      >>      -Steve
    >      >>      On 5/30/2017 2:12 PM, Martin Moore wrote:
    >      >>      > Hi,
    >      >>      > On Debian Jessie 64bit, postgis 2.3, postgres 9.6 (both
    >      >> installed using
    >      >>      > apt-get)
    >      >>      > I can’t create postgis extension
    >      >>      >   psql -d mydb -c "CREATE EXTENSION postgis;"
    >      >>      > ERROR:  could not load library
    >      >>      > "/usr/lib/postgresql/9.6/lib/postgis-2.3.so":
    >      >>      > /usr/lib/postgresql/9.6/lib/postgis-2.3.so: undefined symbol:
    >      >>      > pj_get_spheroid_defn
    >      >>      > But it is there:
    >      >>      >   objdump -t -T /usr/lib/postgresql/9.6/lib/postgis-2.3.so |
    >      >> grep defn
    >      >>      > 0000000000000000      DF *UND* 0000000000000000
    >      >>      > It appears to have proj 4.8
    >      >>      > ii  libproj0                               4.8.0-5
    >      >>      > ii  proj-bin                               4.8.0-5
    >      >> library (datum
    >      >>      > package)
    >      >>      > I’m not a Linux guru and this has me stumped!
    >      >>      > What am I missing?
    >      >>      > Thanks,
    >      >>      > Martin.
    >      >>      > _______________________________________________
    >      >>      > postgis-users mailing list
    >      >>      > postgis-users at lists.osgeo.org
    >      >>      > https://lists.osgeo.org/mailman/listinfo/postgis-users
    >      >>      This email has been checked for viruses by Avast antivirus software.
    >      >>      https://www.avast.com/antivirus
