[postgis-users] Importing relations from database where postgis extension was created with a different schema
Andrew Joseph ap.joseph at live.com
Tue Nov 7 12:44:55 PST 2017
 I have the following databases:
db1 - postgres 9.4 postgis 2.2 with postgis installed in a schema named
"postgis"
db2 - postgres 10 postgis 2.4 with postgis installed in public schema
I am attempting to copy tables from myschema in db1 into db2 via pg_dump:
sudo -u postgres pg_dump -n myschema db1 | psql --username=postgres
--host=172.18.0.3 --dbname=db2
predictably this yields the following error:
ERROR:  type "postgis.geometry" does not exist
LINE 8:     geom postgis.geometry(MultiPolygon,4326)
This error results in the relevant tables not being created and corrupts the
entire import process. Since the postgis extension location now cannot be
altered, how do I import the data without issue? (I switched from using a
specific postgis schema to using public in db2 -since this seems to be
preferred)
Sent from: http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html
