[postgis-users] How can I update proj4 without recompile
Guido Stein
gstein at appgeo.com
Tue Nov 28 09:59:27 PST 2017
Hey folks,
I am trying to update the proj4 libraries on my postgis because I think the
older version of proj4 is giving me faulty areas (known bug). I would like
to go from 4.8 to 4.9.
In talking to some friends I found out that I can make a sym link from the
existing proj4 to a newly compiled proj4 without an issue. But, I can't
seem to figure that out completely and need a little help.
# Here is what is running on my system:
select version();
PostgreSQL 9.5.10 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
select postgis_full_version();
POSTGIS="2.3.3 r15473"
GEOS="3.4.2-CAPI-1.8.2 r3921"
PROJ="Rel. 4.8.0, 6 March 2012"
GDAL="GDAL 1.10.1, released 2013/08/26"
LIBXML="2.9.1"
LIBJSON="0.11.99"
RASTER
# here is what I have done so far:
- locate the directory of the postgis
pg_congif --pkglibdir
- get information about what libraries are associated with postgis
ldd postgis-2.3
libproj.so.0 => /usr/lib/libproj.so.0 (0x00007ff19e1dd000)
# this is where I loose the thread
I don't know if when I make install if there should be a file I need to
link here?? Yeah I need a clue and would be grateful for any assistance on
this.
-guido
This e-mail message and any attachments may contain confidential or legally
privileged information. If you are not an intended recipient or otherwise
authorized to receive this message, you should not use, copy, distribute,
disclose or take any action based on the information contained in this
e-mail or any attachments. If you have received this message and material
in error, please advise the sender immediately by reply e-mail and delete
this message. Thank you on behalf of Applied Geographics, Inc. (AppGeo).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171128/4868719d/attachment.html>
