[postgis-users] postgis-users Digest, Vol 194, Issue 3
b.j.kobben at utwente.nl b.j.kobben at utwente.nl
Sun Apr 8 03:05:57 PDT 2018
Please refer from using other languages, this is an english language list....
Barend Köbben
On 08/04/2018, 11:25, "postgis-users on behalf of Freddy Gonthier" <postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> on behalf of freddy.gonthier at gmail.com<mailto:freddy.gonthier at gmail.com>> wrote:
Bonjour,
Il faut que l’application qui ouvre le fichier avec les données sources le fasse avec le même code page que celui qui a été utiliser pour écrire les enregistrements du fichier source. Attention, il existe des limites connues comme un fichier source écrit avec plusieurs code page, ou encore, les caractères du code page du fichier sources ne sont pas tous transposables vers le code page de la base données.
Cordialement,
F. Gonthier
2018-04-07 21:00 GMT+02:00 <postgis-users-request at lists.osgeo.org<mailto:postgis-users-request at lists.osgeo.org>>:
Send postgis-users mailing list submissions to
        postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.osgeo.org/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        postgis-users-owner at lists.osgeo.org<mailto:postgis-users-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of postgis-users digest..."
Today's Topics:
   1. Encoding and Collation Question (Aaron Edwards)
   2. Re: Encoding and Collation Question
      (Darafei Komяpa Praliaskouski)
   3. Re: Encoding and Collation Question (Gary Turner)
Message: 1
Date: Fri, 6 Apr 2018 22:05:37 +0000
From: Aaron Edwards <aedwards at b3insight.com<mailto:aedwards at b3insight.com>>
To: "postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>" <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: [postgis-users] Encoding and Collation Question
Message-ID:
        <DM5PR1301MB20585A056DB69B2ABE409EFB91BA0 at DM5PR1301MB2058.namprd13.prod.outlook.com<mailto:DM5PR1301MB20585A056DB69B2ABE409EFB91BA0 at DM5PR1301MB2058.namprd13.prod.outlook.com>>
Content-Type: text/plain; charset="utf-8"
I'm trying to create a spatial layer in GoeServer using postgis.  The problem is that there are a few special characters in the name column (rivers and streams in New Mexico).  In Zuni river, for example, the N has a tilde character over it.  So the labels are all wonky.
What Encoding and Collation would prevent this?  I tried WIN1252 and English_United States.1252, but that prevented me from installing the ogr_fdw extension, and that seemed to preclude the use of UpdateGeometrySRID(), which I need.
Thanks.
Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180406/259dd5f8/attachment-0001.html>
Message: 2
Date: Sat, 07 Apr 2018 11:23:17 +0000
From: Darafei "Komяpa" Praliaskouski <me at komzpa.net<mailto:me at komzpa.net>>
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: Re: [postgis-users] Encoding and Collation Question
Message-ID:
        <CAC8Q8t+UxG9WbQTepaPBkUQcvorPhUYxiSKVCEmzJAOL+fwASg at mail.gmail.com<mailto:CAC8Q8t%2BUxG9WbQTepaPBkUQcvorPhUYxiSKVCEmzJAOL%2BfwASg at mail.gmail.com>>
If something from one character becomes two or more characters, you're
dealing with multibyte encoding, most likely UTF-8.
сб, 7 апр. 2018 г. в 1:05, Aaron Edwards <aedwards at b3insight.com<mailto:aedwards at b3insight.com>>:
> Hi,
> I’m trying to create a spatial layer in GoeServer using postgis.  The
> Thanks.
> Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180407/119732c4/attachment-0001.html>
Message: 3
Date: Sun, 8 Apr 2018 00:15:45 +1200
From: Gary Turner <g at elizr.com<mailto:g at elizr.com>>
To: postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
Message-ID: <841617ea-d425-d43f-33ae-7e5ab7b920a8 at elizr.com<mailto:841617ea-d425-d43f-33ae-7e5ab7b920a8 at elizr.com>>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
IIRC, postgres/gis tables are UTF-8 by default.  That's probably the
best option to use to avoid hassles, and to be more stable long-term.
If you are having problems, I suspect that the issue is what encoding
your source data was/is in, and what process you used to import it.
Can you do it again? What process did you use? Do you know what encoding
it was in?
On 07/04/18 10:05, Aaron Edwards wrote:
> Hi,
> Thanks.
> Aaron
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180408/55f6da7c/attachment-0001.html>
Subject: Digest Footer
End of postgis-users Digest, Vol 194, Issue 3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180408/27b8841f/attachment.html>
