[postgis-users] postgis-users Digest, Vol 194, Issue 3
Freddy Gonthier freddy.gonthier at gmail.com
Sun Apr 8 02:24:45 PDT 2018
Bonjour,
Il faut que l’application qui ouvre le fichier avec les données sources le
fasse avec le même code page que celui qui a été utiliser pour écrire les
enregistrements du fichier source. Attention, il existe des limites connues
comme un fichier source écrit avec plusieurs code page, ou encore, les
caractères du code page du fichier sources ne sont pas tous transposables
vers le code page de la base données.
Cordialement,
F. Gonthier
2018-04-07 21:00 GMT+02:00 <postgis-users-request at lists.osgeo.org>:
> Send postgis-users mailing list submissions to
>         postgis-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/postgis-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         postgis-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
>    1. Encoding and Collation Question (Aaron Edwards)
>    2. Re: Encoding and Collation Question
>       (Darafei Komяpa Praliaskouski)
>    3. Re: Encoding and Collation Question (Gary Turner)
> Message: 1
> Date: Fri, 6 Apr 2018 22:05:37 +0000
> From: Aaron Edwards <aedwards at b3insight.com>
> To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
> Subject: [postgis-users] Encoding and Collation Question
> Message-ID:
>         <DM5PR1301MB20585A056DB69B2ABE409EFB91BA0 at DM5PR1301MB2058.
> namprd13.prod.outlook.com>
> Content-Type: text/plain; charset="utf-8"
> Hi,
> I'm trying to create a spatial layer in GoeServer using postgis.  The
> problem is that there are a few special characters in the name column
> (rivers and streams in New Mexico).  In Zuni river, for example, the N has
> a tilde character over it.  So the labels are all wonky.
> What Encoding and Collation would prevent this?  I tried WIN1252 and
> English_United States.1252, but that prevented me from installing the
> ogr_fdw extension, and that seemed to preclude the use of
> UpdateGeometrySRID(), which I need.
> Thanks.
> Aaron
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/postgis-users/
> attachments/20180406/259dd5f8/attachment-0001.html>
> Message: 2
> Date: Sat, 07 Apr 2018 11:23:17 +0000
> From: Darafei "Komяpa" Praliaskouski <me at komzpa.net>
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] Encoding and Collation Question
> Message-ID:
>         <CAC8Q8t+UxG9WbQTepaPBkUQcvorPhUYxiSKVC
> EmzJAOL+fwASg at mail.gmail.com>
> If something from one character becomes two or more characters, you're
> dealing with multibyte encoding, most likely UTF-8.
> сб, 7 апр. 2018 г. в 1:05, Aaron Edwards <aedwards at b3insight.com>:
> > Hi,
> > I’m trying to create a spatial layer in GoeServer using postgis.  The
> has
> > Thanks.
> > Aaron
> attachments/20180407/119732c4/attachment-0001.html>
> Message: 3
> Date: Sun, 8 Apr 2018 00:15:45 +1200
> From: Gary Turner <g at elizr.com>
> To: postgis-users at lists.osgeo.org
> Message-ID: <841617ea-d425-d43f-33ae-7e5ab7b920a8 at elizr.com>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> IIRC, postgres/gis tables are UTF-8 by default.  That's probably the
> best option to use to avoid hassles, and to be more stable long-term.
> If you are having problems, I suspect that the issue is what encoding
> your source data was/is in, and what process you used to import it.
> Can you do it again? What process did you use? Do you know what encoding
> it was in?
> On 07/04/18 10:05, Aaron Edwards wrote:
> > Hi,
> > has a tilde character over it.  So the labels are all wonky.
> > Thanks.
> > Aaron
> attachments/20180408/55f6da7c/attachment-0001.html>
> Subject: Digest Footer
> End of postgis-users Digest, Vol 194, Issue 3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180408/3508eb69/attachment.html>
