[postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Gary Turner g at elizr.com
Tue Apr 17 16:36:29 PDT 2018
I guess it should be obvious, but have you checked that your temp
variable does point somewhere writeable?
On 17/04/2018 23:09, Jibran Khan wrote:
> Hello,
> Apologies if this is an irrelevant question, here.
> I have been trying to install PostgreSQL 9.5.11 on Windows 10 (x64)
> using Enterprise DB interactive installer. But, no success.
> I keep getting this error.
> I am aware about the BigSQL installers but I prefer the Enterprise DB
> one :).
> I came across the similar issue here:
> https://stackoverflow.com/questions/46118851/unable-to-install-postgresql-on-windows-10
> A little googling routed me towards some proposed solutions (here
> <http://1stopit.blogspot.dk/2011/01/postgresql-83-and-84-fails-to-install.html>
> and here
> <https://serverfault.com/questions/230219/vbscript-wont-run-for-domain-user-on-windows-server-2008-r2>).
> I tried them but, no success.
> Here is the error message, I am getting.
> Can somebody suggest the workaround to fix this issue?
> Log started 04/17/2018 at 11:28:34
>     Preferred installation mode : qt
>     Trying to init installer in mode qt
>     Mode qt successfully initialized
>     Executing
> C:\my_user\AppData\Local\Temp/postgresql_installer_676baef523/temp_check_comspec.bat
>     Script exit code: 0
>     Script output:
>      "test ok"
>     Script stderr:
>     Could not find registry key
> HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5
> Data Directory. Setting variable iDataDirectory to empty value
> Base Directory. Setting variable iBaseDirectory to empty value
> Service ID. Setting variable iServiceName to empty value
> Service Account. Setting variable iServiceAccount to empty value
> Super User. Setting variable iSuperuser to empty value
> Branding. Setting variable iBranding to empty value
> Version. Setting variable brandingVer to empty value
> Shortcuts. Setting variable iShortcut to empty value
> DisableStackBuilder. Setting variable iDisableStackBuilder to empty value
>     [11:28:39] Existing base directory:
>     [11:28:39] Existing data directory:
>     [11:28:39] Using branding: PostgreSQL 9.5
>     [11:28:39] Using Super User: postgres and Service Account: NT
> AUTHORITY\NetworkService
>     [11:28:39] Using Service Name: postgresql-x64-9.5
>     Executing cscript //NoLogo
> "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs"
>     Script exit code: 1
>     Script output:
>      CScript Error: Loading script
> failed (Access is denied. ).
>     Script stderr:
>      Program ended with an error exit code
>     Error running cscript //NoLogo
> "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs":
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180418/a6a53ce5/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180418/a6a53ce5/attachment.png>
