[postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Jibran Khan jibran at envs.au.dk
Tue Apr 17 14:15:12 PDT 2018
I think, I tried it already.
But - thanks for the suggestion. I will try again and will report, if it resolves the issue.
Jibran
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Regina Obe
Sent: 17 April 2018 21:49
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Other possibility is your virus protection software or some other software is blocking it.
Did you try turning off your virus protection software or checking the event logs of it (or other protection services)
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jibran Khan
Sent: Tuesday, April 17, 2018 3:26 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Hi Regina,
Yes, I did already.
Thank you for the suggestion.
Best,
Jibran
Sent: 17 April 2018 17:45
Jibran,
Given this is not a PostGIS question, you should ask this on pg-general list instead.
https://www.postgresql.org/list/pgsql-general/
One thought, did you run the installer as an Administrator - Right click --> Run As Administrator?
Thanks,
Regina
Sent: Tuesday, April 17, 2018 7:09 AM
Subject: [postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Hello,
Apologies if this is an irrelevant question, here.
I have been trying to install PostgreSQL 9.5.11 on Windows 10 (x64) using Enterprise DB interactive installer. But, no success.
I keep getting this error.
[cid:image001.png at 01D3D6A1.EBADA1E0]
I am aware about the BigSQL installers but I prefer the Enterprise DB one :).
I came across the similar issue here:
https://stackoverflow.com/questions/46118851/unable-to-install-postgresql-on-windows-10
A little googling routed me towards some proposed solutions (here<http://1stopit.blogspot.dk/2011/01/postgresql-83-and-84-fails-to-install.html> and here<https://serverfault.com/questions/230219/vbscript-wont-run-for-domain-user-on-windows-server-2008-r2>).
I tried them but, no success.
Here is the error message, I am getting.
Can somebody suggest the workaround to fix this issue?
Log started 04/17/2018 at 11:28:34
    Preferred installation mode : qt
    Trying to init installer in mode qt
    Mode qt successfully initialized
    Executing C:\my_user\AppData\Local\Temp/postgresql_installer_676baef523/temp_check_comspec.bat
    Script exit code: 0
    Script output:
     "test ok"
    Script stderr:
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Data Directory. Setting variable iDataDirectory to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Base Directory. Setting variable iBaseDirectory to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Service ID. Setting variable iServiceName to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Service Account. Setting variable iServiceAccount to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Super User. Setting variable iSuperuser to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Branding. Setting variable iBranding to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Version. Setting variable brandingVer to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Shortcuts. Setting variable iShortcut to empty value
    Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 DisableStackBuilder. Setting variable iDisableStackBuilder to empty value
    [11:28:39] Existing base directory:
    [11:28:39] Existing data directory:
    [11:28:39] Using branding: PostgreSQL 9.5
    [11:28:39] Using Super User: postgres and Service Account: NT AUTHORITY\NetworkService
    [11:28:39] Using Service Name: postgresql-x64-9.5
    Executing cscript //NoLogo "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs"
    Script exit code: 1
    Script output:
     CScript Error: Loading script "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs" failed (Access is denied. ).
    Script stderr:
     Program ended with an error exit code
    Error running cscript //NoLogo "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs": Program ended with an error exit code
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/0731af8f/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/0731af8f/attachment.png>
