[postgis-users] ST_AsMVT Centos 7 Missing libprotobuf-c
Devrim Gündüz
devrim at gunduz.org
Thu Apr 26 14:25:22 PDT 2018
I will work on this next week -- can you please let me know how I can test that
this feature works, so that I release the package safely?
Regards, Devrim
On Tue, 2018-01-09 at 15:56 +0000, David MacDonald wrote:
> Hi,
> I’m currently working on a Mapbox tile server using the new MVT support in
> Postgis 2.4. I’ve been testing with a local docker image of Postgres/Postgis
> and all is going well.
> However, I’ve moved to testing on a CentOS 7 VM, and have run into an issue.
> So I installed Postgres as follows:
> sudo yum -y install https://download.postgresql.org/pub/repos/yum/10/redhat/r
> hel-7-x86_64/pgdg-centos10-10-1.noarch.rpm
> sudo yum -y install postgresql10-server postgresql10 postgis24_10
> postgis24_10-utils postgis24_10-client
> sudo /usr/pgsql-10/bin/postgresql-10-setup initdb
> sudo systemctl enable postgresql-10
> sudo systemctl start postgresql-10
> I’ve also enabled the posts extensions.
> However, when I execute an ST_AsMVT query, I get the following error:
> 2018-01-09 23:32:31.122 AWST [9913] ERROR: Missing libprotobuf-c
> I’ve Googled about, but I can’t seem to find anything conclusive.
> I tried installing protobuf:
> sudo yum install protobuf protobuf-c
> And restarting Postgres, but still the issue persists.
> Any help or direction would be very much appreciated.
> David.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Devrim Gündüz
EnterpriseDB: https://www.enterprisedb.com
PostgreSQL Consultant, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180427/992d8c0c/attachment.sig>
