[postgis-users] MGRS reference system
Lars laasunde at hotmail.com
Thu Aug 23 23:02:58 PDT 2018
Jim,
Thank you for a very helpful feedback on MGRS and its oddity 😊
Will consider your binding solution.
Lars
Fra: postgis-users <postgis-users-bounces at lists.osgeo.org> på vegne av Jim Klassen <klassen.js at gmail.com>
Sendt: onsdag 22. august 2018 19.03
Til: postgis-users at lists.osgeo.org
Emne: Re: [postgis-users] MGRS reference system
I have done a lot of work with the US National Grid (USNG) which is very similar to the MGRS. It is a bit of an odd coordinate system because it uses one string rather than two numbers for the coordinate, as such it doesn't really fit into a geometry type directly (and that is ignoring that it technically defines areas not points).
To deal with this, I store the coordinates in a "normal" coordinate system in PostGIS and wrote a PostgreSQL binding to my C++ library to convert to/from the string form only for input/output [1].  I have developed and tested this in so far as what I have needed personally.  I'm sure there is further work needed (PRs welcome).  Also, note I've done all this on Linux and have no idea if it works under Windows.
Another (potentially more Windows friendly) option could be to use PL/v8 and adapt my JavaScript USNG implementation [2] or the Proj4JS MGRS implementation [3].
[1] https://github.com/klassenjs/usng-tools-cxx
[2] https://github.com/klassenjs/usng-tools-js
[3] https://github.com/proj4js/mgrs
On 08/22/2018 04:01 AM, Per-Olof Norén wrote:
Have a look at UTM.
MGRS is using UTM and UPS.
/p
22 aug. 2018 kl. 10:18 skrev Lars <laasunde at hotmail.com<mailto:laasunde at hotmail.com>>:
Hello,
Does PostGIS support MGRS reference system? If no, are there any plans to add support for this reference system?
Viewing the spatial_ref_sys table there is no entry name MGRS or similar.
Using Windows 10, PostgreSQL 10.3 and PostGIS 2.4.4
Appreciate any response.
kind regards, Lars
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180824/ae11f1c8/attachment.html>
