[postgis-users] Improvement suggestion
Simon (SPDBA) Greener
simon at spatialdbadvisor.com
Sun Dec 2 14:06:34 PST 2018
Did anyone else spot that the person created his target table, created an index on that (empty) table, then inserted all the data in it using St_intersection? He should create the index afterwards.
Sent from BlueMail
On 3 Dec. 2018, 08:41, at 08:41, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>Try the solution outlined here:
>https://gis.stackexchange.com/questions/31310/acquiring-arcgis-like-speed-in-postgis
>On Sun, Dec 2, 2018 at 10:44 AM Paul van der Linden <
>paul.doskabouter at gmail.com> wrote:
>> As I am working with large polygons, I'm always struggling with
>> performance, and trying to find ways to improve them.
>> F.e. I have lots of queries like:
>> SELECT ST_Intersection(table1.geom,table2.geom)
>> FROM table1
>> JOIN table2 on ST_Intersects(table1.geom,table2.geom)
>> In case of large polygons this is sometimes a bottleneck, and I have
>the
>> following suggestion:
>> Create a function which returns the relation between 2 polygons
>(within,
>> intersects or disjunct) so that I can do the following:
>> SELECT
>> CASE
>> WHEN ST_Relate(table1.geom,table2.geom)=intersects THEN
>> ELSE table1.geom
>> END
>> FROM table1
>> JOIN table2 on ST_Relate(table1.geom,table2.geom) IN
>(intersects,within)
>> or (because ST_Relate is calculated twice in previous query):
>> SELECT
>> CASE
>> WHEN relate=intersects THEN ST_Intersection(t1geom,t2geom)
>> ELSE t1geom
>> END
>> FROM (
>> SELECT ST_Relate(table1.geom,table2.geom) as relate,table1.geom AS
>> t1geom,table2.geom AS t2geom FROM table1
>> JOIN table2 on table1.geom && table2.geom
>> ) AS allpolies
>> WHERE relate IN (intersects,within)
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181203/30626634/attachment.html>
