[postgis-users] Very long query time
Manchon Pierre pierre.manchon at irstea.fr
Thu Dec 6 08:24:20 PST 2018
It is pretty simple :
The query take data from the orange tables and insert it into the purple one
De : postgis-users <postgis-users-bounces at lists.osgeo.org> De la part de
Tumasgiu Rossini
Envoyé : jeudi 6 décembre 2018 17:19
À : PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Objet : Re: [postgis-users] Very long query time
And I am not really sure that what you are willing to achieve with the GROUP
BY
I am not aware of you data model, though.
Maybe you have upgraded recently to postgis 2.4 which change GROUP BY
behavior
when it comes to geometries [1]?
Geometries in 2.4 are no more grouped using bbox comparison but using strict
equality (st_equals)
[1]http://blog.cleverelephant.ca/2017/09/postgis-operators.html
Le jeu. 6 déc. 2018 à 17:09, Tumasgiu Rossini <rossini.t at gmail.com
<mailto:rossini.t at gmail.com> > a écrit :
I do not really understand.
Is it a query which used to be faster ?
A little remark on your where clause :
it is unnecesseraly complicated and could be shortened to :
    WHERE st_intersects(zi.geom, tile.geom)
True and false value doesn't need to be surronded by quote,
here you are implicitly casting the string value 'true' to its boolean
representation
Le jeu. 6 déc. 2018 à 16:53, Manchon Pierre <pierre.manchon at irstea.fr
<mailto:pierre.manchon at irstea.fr> > a écrit :
Hello there,
I'm new on the list and for a premiere I would like to know if some of you
have a very long runtime for some of their queries (even with a LIMIT 5),
whereas those queries were working well before (nothing changed from that).
I'm using Postgre10, pgAdmin4 and postgis 2.4.4 on windows …
The infinite query I’m trying to execute: (only ~500 rows are stored on each
of the two tables)
SELECT code_tile, code_zi FROM data.tile, data.zi
WHERE ST_Intersects(zi.geom, tile.geom) = 'true'
GROUP BY code_zi, code_tile, zi.geom, tile.geom
LIMIT 5
Thank you for your time
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/ce96c5e9/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/ce96c5e9/attachment.png>
