[postgis-users] Very long query time
Tumasgiu Rossini
rossini.t at gmail.com
Thu Dec 6 08:18:56 PST 2018
And I am not really sure that what you are willing to achieve with the
GROUP BY
I am not aware of you data model, though.
Maybe you have upgraded recently to postgis 2.4 which change GROUP BY
behavior
when it comes to geometries [1]?
Geometries in 2.4 are no more grouped using bbox comparison but using
strict equality (st_equals)
[1]http://blog.cleverelephant.ca/2017/09/postgis-operators.html
Le jeu. 6 déc. 2018 à 17:09, Tumasgiu Rossini <rossini.t at gmail.com> a
écrit :
> I do not really understand.
> Is it a query which used to be faster ?
> A little remark on your where clause :
> it is unnecesseraly complicated and could be shortened to :
> WHERE st_intersects(zi.geom, tile.geom)
> True and false value doesn't need to be surronded by quote,
> here you are implicitly casting the string value 'true' to its boolean
> representation
> Le jeu. 6 déc. 2018 à 16:53, Manchon Pierre <pierre.manchon at irstea.fr> a
> écrit :
>> Hello there,
>> I'm new on the list and for a premiere I would like to know if some of
>> you have a very long runtime for some of their queries (even with a LIMIT
>> 5), whereas those queries were working well before (nothing changed from
>> that). I'm using Postgre10, pgAdmin4 and postgis 2.4.4 on windows …
>> The infinite query I’m trying to execute: (only ~500 rows are stored on
>> each of the two tables)
>> SELECT code_tile, code_zi FROM data.tile, data.zi
>> WHERE ST_Intersects(zi.geom, tile.geom) = 'true'
>> GROUP BY code_zi, code_tile, zi.geom, tile.geom
>> LIMIT 5
>> Thank you for your time
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/89e9dbc0/attachment.html>
