[postgis-users] Very long query time
Manchon Pierre pierre.manchon at irstea.fr
Thu Dec 6 08:56:16 PST 2018
Okay that works good now thank you !
Sorry I should’ve taken a look at this which is a bit obvious now I know
where was the error.
De : postgis-users <postgis-users-bounces at lists.osgeo.org> De la part de
Darafei "Kom?pa" Praliaskouski
Envoyé : jeudi 6 décembre 2018 17:43
À : PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Objet : Re: [postgis-users] Very long query time
did you create spatial index on your geometry?
your screenshot also does not show any geometry field.
On Thu, Dec 6, 2018 at 7:29 PM Manchon Pierre <pierre.manchon at irstea.fr
<mailto:pierre.manchon at irstea.fr> > wrote:
Hello,
The indexes are code_zoneinteret and code_tuile on recouvrement
<mailto:postgis-users-bounces at lists.osgeo.org> > De la part de Darafei
Envoyé : jeudi 6 décembre 2018 17:18
<mailto:postgis-users at lists.osgeo.org> >
Hello,
What are the indexes on the table?
On Thu, Dec 6, 2018 at 7:16 PM Manchon Pierre <
<mailto:pierre.manchon at irstea.fr> pierre.manchon at irstea.fr> wrote:
Yes the request took about ~100ms to be executed before but now it never
ends (I left it 1h)
(thx for the tip with where clause)
De : postgis-users < <mailto:postgis-users-bounces at lists.osgeo.org>
postgis-users-bounces at lists.osgeo.org> De la part de Tumasgiu Rossini
Envoyé : jeudi 6 décembre 2018 17:09
À : PostGIS Users Discussion < <mailto:postgis-users at lists.osgeo.org>
I do not really understand.
Is it a query which used to be faster ?
A little remark on your where clause :
it is unnecesseraly complicated and could be shortened to :
    WHERE st_intersects(zi.geom, tile.geom)
True and false value doesn't need to be surronded by quote,
here you are implicitly casting the string value 'true' to its boolean
representation
Le jeu. 6 déc. 2018 à 16:53, Manchon Pierre <pierre.manchon at irstea.fr
<mailto:pierre.manchon at irstea.fr> > a écrit :
Hello there,
I'm new on the list and for a premiere I would like to know if some of you
have a very long runtime for some of their queries (even with a LIMIT 5),
whereas those queries were working well before (nothing changed from that).
I'm using Postgre10, pgAdmin4 and postgis 2.4.4 on windows …
The infinite query I’m trying to execute: (only ~500 rows are stored on each
of the two tables)
SELECT code_tile, code_zi FROM data.tile, data.zi
WHERE ST_Intersects(zi.geom, tile.geom) = 'true'
GROUP BY code_zi, code_tile, zi.geom, tile.geom
LIMIT 5
Thank you for your time
postgis-users mailing list
 <mailto:postgis-users at lists.osgeo.org> postgis-users at lists.osgeo.org
 <https://lists.osgeo.org/mailman/listinfo/postgis-users>
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/98dc5a1f/attachment.html>
