[postgis-users] ST_AsMVT Centos 7 Missing libprotobuf-c
David MacDonald
davidm at yambay.com
Tue Jan 9 07:56:30 PST 2018
I’m currently working on a Mapbox tile server using the new MVT support in Postgis 2.4. I’ve been testing with a local docker image of Postgres/Postgis and all is going well.
However, I’ve moved to testing on a CentOS 7 VM, and have run into an issue.
So I installed Postgres as follows:
sudo yum -y install https://download.postgresql.org/pub/repos/yum/10/redhat/rhel-7-x86_64/pgdg-centos10-10-1.noarch.rpm
sudo yum -y install postgresql10-server postgresql10 postgis24_10 postgis24_10-utils postgis24_10-client
sudo /usr/pgsql-10/bin/postgresql-10-setup initdb
sudo systemctl enable postgresql-10
sudo systemctl start postgresql-10
I’ve also enabled the posts extensions.
However, when I execute an ST_AsMVT query, I get the following error:
2018-01-09 23:32:31.122 AWST [9913] ERROR: Missing libprotobuf-c
I’ve Googled about, but I can’t seem to find anything conclusive.
I tried installing protobuf:
sudo yum install protobuf protobuf-c
And restarting Postgres, but still the issue persists.
Any help or direction would be very much appreciated.
David.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180109/11a6a28d/attachment.html>
