[postgis-users] ST_AsMVT Centos 7 Missing libprotobuf-c
Björn Harrtell
bjorn.harrtell at gmail.com
Tue Jan 9 10:55:38 PST 2018
Hi David,
The problem is likely that the CentOS 7 packaged version of PostGIS 2.4 was
not made in a way to support protobuf-related functions (including
ST_AsMVT).
It does not help adding protobuf-c as a package later, it needs to be
depended on by the postgis package and available when the package is/was
created.
So, you will either have to convince the responsible for the package to
depend on the required things for protobuf-related functions or find an
alternative distribution of the package, or build postgis yourself.
Notes on the protobuf-related (optional) requirements are listed at:
https://postgis.net/docs/manual-2.4/postgis_installation.html#install_requirements
/Björn
2018-01-09 16:56 GMT+01:00 David MacDonald <davidm at yambay.com>:
> Hi,
> I’m currently working on a Mapbox tile server using the new MVT support in
> Postgis 2.4. I’ve been testing with a local docker image of
> Postgres/Postgis and all is going well.
> However, I’ve moved to testing on a CentOS 7 VM, and have run into an
> issue.
> So I installed Postgres as follows:
> sudo yum -y install https://download.postgresql.org/pub/repos/yum/10/redhat/rhel-7-x86_64/pgdg-centos10-10-1.noarch.rpm
> sudo yum -y install postgresql10-server postgresql10 postgis24_10 postgis24_10-utils postgis24_10-client
> sudo /usr/pgsql-10/bin/postgresql-10-setup initdb
> sudo systemctl enable postgresql-10
> sudo systemctl start postgresql-10
> I’ve also enabled the posts extensions.
> However, when I execute an ST_AsMVT query, I get the following error:
> 2018-01-09 23:32:31.122 AWST [9913] ERROR: Missing libprotobuf-c
> I’ve Googled about, but I can’t seem to find anything conclusive.
> I tried installing protobuf:
> sudo yum install protobuf protobuf-c
> And restarting Postgres, but still the issue persists.
> Any help or direction would be very much appreciated.
> David.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180109/9dc1be3e/attachment.html>
