[postgis-users] Error upgrading to PostGIS 2.4.3
Regina Obe
lr at pcorp.us
Tue Mar 20 16:36:15 PDT 2018
Ross,
That error often means there is a dependency missing.
I think I did upgrade some binaries like GDAL and GEOS in last run, so if
you were upgrading while PostGIS lib was in use, you might have gotten an
error like
"Can't overwrite file" during installation and since 2.4.3 would need the
newer GDAL/GEOS/Proj might fail. That would cause this problem. Fix would
be shut down postgresql, restart and rerun the 2.4.3 setup.
Could also be a packaging mistake on my part.
I'll test on my end on a clean 64-bit 9.6.8 to rule out issue on my end.
Last time I had a large number of people complaining about this, it was
because EDB micro upgraded installed a libeasy32.dll that was incompatible
with the curl I was shipping, so I had to recompile the curl to be
compatible with whatever EDB upgraded their SSL libraries to.
Given your 2.3.5 still works? I assume the ssl is not the issue.
Thanks.
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of McDonaldR
Sent: Tuesday, March 20, 2018 2:00 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Error upgrading to PostGIS 2.4.3
Hi List
Maybe you can point me in the right direction. I'm running PostgreSQL 9.6.8
(64bit) on Windows 2008 R2 with PostGIS 2.3.5 installed. I have installed
the 2.4.3 binaries and when I try to run ALTER EXTENSION postgis UPDATE TO
"2.4.3"; I get the following error:
ERROR could not load library PostgreSQL/9.6/lib/postgis-2.4.dll The
specified procedure could not be found.
The file is there. I've checked permissions and all are valid. I've
stopped and started the postgresql service. Am I missing something going
from PostGIS 2.3.x to 2.4.x? In the past upgrades have been totally
painless.
Any help much appreciated.
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Angus Council, People, IT | Angus
House, Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT | t: 01307
476419
This message is strictly confidential. If you have received this in error,
please inform the sender and remove it from your system. If received in
error you may not copy, print, forward or use it or any attachment in any
way. This message is not capable of creating a legal contract or a binding
representation and does not represent the views of Angus Council. Emails may
be monitored for security and network management reasons. Messages
containing inappropriate content may be intercepted. Angus Council does not
accept any liability for any harm that may be caused to the recipient system
or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180320/58833341/attachment.html>
